Engine Harness Replacement - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.4L Power Stroke Diesel
Reload this Page >
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 02-15-2019, 02:28 PM
vlietracer64
vlietracer64 is offline
vlietracer64 is starting off with a positive reputation.
Exclamation Engine Harness Replacement
Has anyone had to replace the complete engine harness and what has to be removed
**Alternator caught on fire and meted harness back under intake of engine,
Was driving and had a rotten egg smell but thought it was car in front of me, must have been alternator over charging batteries. Stopped for lunch and as i pulled in heard a bearing noise, assuming water pump or idler pulley. Came out after lunch to smoke pouring out wheel well and hood, was glowing at alternator and couldn't put it out, disconnect batteries and then got snow on it to put out. Looks like maybe diode shorted out and heated up to cause fire but not enough current to blow fuse-able link in alternator to battery connection.
Fire damaged; alternator, belt, A/C line, Wire-Harness melted back into intake area, hard plastic line (looks like vent)
Dose cab have to come off?
I've also have had fuel pump volume control codes come up 2-3 time during hot weather while at running temp and accelerating so might be a good time to replace it if cab has to come off now?
2010 F350
6.4L
215,000
Deleted / Spartan Tunes
Old 02-15-2019, 04:00 PM
Fefanatic
Fefanatic is offline
Fefanatic is starting off with a positive reputation.
I plan to part out a '08 6.4 next week. I may have that harness available by the end of next week. Check the rest of your wiring to be sure it is OK.
Old 02-15-2019, 04:11 PM
vlietracer64
OK thanks, going to pull cab Sunday and check everything out and decide to replace HPFP while im in there.
Old 02-16-2019, 11:28 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
speakerfritz has a good reputation on FTE.speakerfritz has a good reputation on FTE.
I dought that your pcm is any good so I would check into that.
the pcm looks like it would be simple to pull out and have it tested .
short circuits and electricity do not play well together
did any fuses blow
this fire starting due to alternator Buisness does happen frequently on these trucks .....some one needs to design a fail safe that would prevent this.
i saw a product once that looked like a hose that you would snake around the engine and if it gets hot, it acts like a fire extinguisher. I may have to look into that
there are at least 2 fuseable links in that system so you will probally need those as well.
good luck and keep us posted
Old 02-16-2019, 11:32 AM
speakerfritz
if that 08 had a dual alternator setup I would be interested in the upgrade brackets, harness, etc for the second alternator located at the top. The top is referd to as the primary in a dual setup . For us with single setups with alternators at the bottom oh wheel well side thatís the secondary position. I have the secondary located at lower pax side wheel well with empty primary located at the top.
Old 02-16-2019, 08:25 PM
DieselDenny
DieselDenny is offline
DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.
I'm eyeballing the root cause. What really could it be?
Denny
Old 02-16-2019, 08:39 PM
vlietracer64
Denny
it was definitely the alternator that started it. I threw snow and tried to blow out flames from wire harness and the back of alternator was glowing and kept re-igniting plastic on back and split loom on wires. Once I disconnected batteries the glow stopped and I was able to put fire out with snow for good. Iím guessing a diode shorted out allowing batter voltage and current into windings causing a short that heated up bad diode till point it started windings and plastic endcap on fire. Guessing fuseable link didnít blow cause it is sized for max alternator output and short that cause fire was Under said amperage.
Should have more pictures tomorrow
fire heated aluminum A\C line till it split and burst
Old 02-16-2019, 08:49 PM
speakerfritz
If you google. ď6.4 alternator fireĒ, youíll see an easy 20 cases, some have videos.
Old 02-16-2019, 09:12 PM
speakerfritz
At first though was thinking to put a 400 amp diode in series with alternator and battery. That way if any of the alternator diode failed, the new in line would prevent reverse voltage. But it would probally be better to just use a large battery isolator ....they are rugged and dissipate heat better.
Old 02-16-2019, 09:24 PM
vlietracer64
I was thinking a heavy duty solenoid or solid state switch that would open circuit between alternator and battery when ignition was off
Old 02-16-2019, 09:29 PM
speakerfritz
Are the fires happening while running or not running?
Old 02-16-2019, 11:07 PM
vlietracer64
This one was while not running
Old 02-17-2019, 11:04 AM
DieselDenny
Did you have Insurance that would cover this?
Denny
Old 02-17-2019, 11:19 AM
Fefanatic
I didn't realize that those alternators had that issue. Once the diodes shorted to ground it was all hell breaking loose. The one way to tell where a short starts is to follow the burned wiring. Since it burned back and including the alternator it's obvious where the fire started. The bad part is those wires burn in the loom which causes other wires to burn and short to their power sources and the next thing you know you have a major mess. If you have insurance it should cover the burn damage but not the alternator. Usually they won't cover the cause but will cover the damage. You might want to check into that. JMO
Old 02-17-2019, 09:03 PM
Firefighter 1406's Avatar
Firefighter 1406
Firefighter 1406 is online now
Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.
Thats a great idea. My dads truck overheated the tranny at the dump. Dumped tranny fluid on the exhaust and caught fire. Insurance company paid to get everything back to normal. Defiantly worth a phone call.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
