Anyone install a Nostalgic Air system in thier truck?
Old 02-12-2019, 02:27 AM
hail destroyer
hail destroyer is online now
hail destroyer is gaining momentum as a positive member of FTE.hail destroyer is gaining momentum as a positive member of FTE.
My work truck (78 supercab 4x4 w/ 400) needs real heat and defrost. I'm removing the broken factory A/C and rotten heater core, and putting a non-AC firewall panel over the gaping factory AC hole..... and am looking at installing a nostalgic air kit.
Any pics, tips, advice would be appreciated. THANKS!
Old 02-12-2019, 01:12 PM
dogdays
dogdays is offline
dogdays is starting off with a positive reputation.
Before you buy..........
DO check out Vintage Air. They started this corner of the aftermarket and have some really decent stuff. The owner of the company is a true hot rodder, deserves our support.
Looks like Nostalgic has a dedicated kit, though. It's really important the defroster can use the A/C system to dehumidify the air, like factory A/C systems do.
R.
Old 02-12-2019, 07:33 PM
TXTrailerdaddy
TXTrailerdaddy is offline
TXTrailerdaddy is starting off with a positive reputation.
Vintage Air doesn't make an AC for our trucks. They make one for the Bump sides though.
Old 02-12-2019, 08:00 PM
9thPony's Avatar
9thPony
9thPony is offline
9thPony is starting off with a positive reputation.
I installed the Nostalgic Air system with heat and defrost in my truck. Was an AC cab as well but I made a block off plate and installed the NAP unit.
It is working well, but the defroster is a little weak because it blows out all the vents. I recently started closing the dash vents when using the defroster and it works much better.
Everything fit nicely and I have no complaints. It makes for a much cleaner engine bay compared to OEM.
You can turn on AC with defrost to help with humidity.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
