How to remove SS interior door panel strip
Old 02-11-2019, 02:16 PM
jackstar
jackstar is offline
jackstar is starting off with a positive reputation.
I want to replace my interior door panels but also want to reuse the SS trim strips. How do I take them off in a manner where I don't damage them? Thanks.
Jack
Old 02-11-2019, 04:32 PM
scottscott
scottscott is offline
scottscott has a good reputation on FTE.scottscott has a good reputation on FTE.
What type of door panel are they on?? Lariat, Ranger, Ranger XLT? And what year of panels?
Some of the trim looks like stainless, but it is really plastic that is heat glued to the door panel. It can be removed, but it is a major pain, & will be destroyed. This is on 79 Lariat panels.
If it is true stainless trim, there are small tabs bent over on the rear of the panel. Straighten out those tabs & the trim comes right off.
Old 02-11-2019, 04:37 PM
jackstar
jackstar is offline
77 F250 CS Ranger and they are Stainless Steel just like the body trim and drip rail trim. I haven't taken the panels off yet so I don't know they are clipped on or glued on.
Old 02-11-2019, 08:11 PM
79 ranger 4x4
79 ranger 4x4 is offline
79 ranger 4x4 is starting off with a positive reputation.
they are attached simply by a hole drilled in the door panel and a tab made to the ss trim bent over to retain it in place. To remove straighten the tabs all the way around and pull off
Old 02-11-2019, 08:12 PM
MrQuick
MrQuick is offline
MrQuick is starting off with a positive reputation.
Just as ScottScott said, the stainless have metal tabs on the back. Straighten them out and trim comes off easily.
Old 02-12-2019, 06:42 AM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Used OEM parts guy
77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.
X3 on straighten out the tab on the back side, CAREFULLY they can break like any metal piece that is bent to many times. And once the tab breaks off, you are left with 2 part epoxy to reattach the trim. But there is LOTS of tabs to bend.....
Use your old holes to make a where to drill pattern for the new holes. I am pretty sure I seen some vendor that offered reproduced trim pieces?? Can't locate it right now.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
