Turbo oil feed upgrade - Ford Truck Enthusiasts Forums
Old 02-11-2019, 01:06 PM
OTR
OTR is offline
OTR is starting off with a positive reputation.
Does this look right ?
Purchased from ford online and picked it up from my local Ford dealer over the weekend. Upon closer inspection the bend at the top where it goes from vertical to horizontal before entering the top of the turbo looks like it is partially collapsed.
If theyre all like this I'll run it but seems wrong since all the other bends on the tube look correct. Anyone want to take a look at theirs to compare ?
k.
Old 02-11-2019, 01:31 PM
Rod Jr.'s Avatar
Rod Jr.
Rod Jr. is offline
Rod Jr. is starting off with a positive reputation.
Does not look right, should look like one on left
Old 02-11-2019, 01:36 PM
OTR
OTR is offline
My pic is the oil supply line that enters the top of the turbo, not the drain.
k.
Old 02-11-2019, 03:23 PM
tfunk88
tfunk88 is offline
tfunk88 is gaining momentum as a positive member of FTE.
Just looked at mine on the truck. I think mine looks like yours but it was freezing rain so I may not have been as thorough as normal
It definitely flattened some at that bend to head back to the top of the turbo
Old 02-11-2019, 07:37 PM
SmackDaddy's Avatar
SmackDaddy
SmackDaddy is offline
SmackDaddy has a great reputation on FTE.SmackDaddy has a great reputation on FTE.SmackDaddy has a great reputation on FTE.SmackDaddy has a great reputation on FTE.
Yes the updated feeds are all like that. I just installed mine with the updated oil cooler cover and turbo drain tube about 8 months ago. Itís all good, my Pmaxís bearings havenít failed with about 10k on it with the new hard feed instead of the old braided section.
Old 02-12-2019, 05:30 AM
Yahiko's Avatar
Yahiko
Yahiko is online now
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Really easy to find just google Ford 6.0L PSD updated turbo oil supply line.
This one happened to be on Ebay.
Old 02-12-2019, 10:22 AM
Rod Jr.'s Avatar
Rod Jr.
Rod Jr. is offline
Does the upgraded oil supply line flow better than the braided line? I already did install the new turbo drain pipe.
Old 02-12-2019, 10:26 AM
copsey's Avatar
copsey
copsey is offline
copsey has a great reputation on FTE.copsey has a great reputation on FTE.copsey has a great reputation on FTE.copsey has a great reputation on FTE.
Same question from me also, have the HPOP cover off for resealing and the oil cooler out for replacement but don't know if I need the hardline or not. Mine is an early build 03 if it makes a difference.
Old 02-12-2019, 10:27 AM
SmackDaddy's Avatar
SmackDaddy
From what I read they made it a one piece hard line because the one with the braided section would fail.
Old 02-12-2019, 10:28 AM
SmackDaddy's Avatar
SmackDaddy
You can’t buy just the hard line, it has a different bottom fitting so you have to buy the upgraded oil cooler cover as well. White Bear Lake is the cheapest, I think my cover and line were around $300
Old 02-12-2019, 11:00 AM
Rod Jr.'s Avatar
Rod Jr.
Rod Jr. is offline
The bottom looks the same as mine, but I have 2006.
Old 02-12-2019, 03:05 PM
Yahiko's Avatar
Yahiko
The ones that have to buy the oil cooler top part are the older engines. I am not sure what the cutoff date is.
But anything from 05 and up should not need a new cover.
The reason as SmackDaddy said is the failure of the braided section. The lining fails and chokes the oil flow.
The only way that you know it failed is your turbo bearings fail do to lack of oil.
You will have to check on what years but the drain was also an issue for the early engines.
The cutoff dates should be in the Tech Folder.
Old 02-12-2019, 05:44 PM
Rod Jr.'s Avatar
Rod Jr.
Rod Jr. is offline
The bottom of my feed line looks the same as one in the picture you posted above. When mine was off I blew through the braided line, no restriction to me but probably better to be safe with the new non braided line. I was told by someone on these forums that the drain pipe was the most important to upgrade. Guess I should just get the new one, that part is almost $100, seems crazy price to pay, but if it saves my new Garrett, then its worth the price.
Old 02-12-2019, 08:27 PM
Yahiko's Avatar
Yahiko
Ebay might also be a place to look.
Old 02-13-2019, 06:10 AM
copsey's Avatar
copsey
copsey is offline
My EX has the upgraded drain tube thankfully but you can find them for $30 or so dollars.
FORD OEM 6.0L V8 TURBO DRAIN TUBE 6C3Z-9T515-A
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
