Best Limited Slip
I have an Aussie in my f150 4x4, auto trans. It's definitely not stealthy on the street. Clunky and loud at times. My father thinks it's mild compared to his old full case Detroit. It bothered me initially in town. I don't know it's there on the highway. Ice, have to mind your right foot a little better. Off road? Traction is insane, and that's the only reason I would install one. Lift a drive tire? No problem, other tire keeps driving. For me that trumps any street quirks. But for winter streets in a 2x4 that will never see serious offroad? Weight and quality tires (severe snow service rated or better) makes way more difference on unplowed or icy streets, without so much tendency to break loose under throttle. I wouldn't lock a street truck unless trying to get a hot rod to hook up. 500+ pounds in the bed with 235 cm wide winter rated tires would be my top choice. That might change if you're not on maintained city streets, but then I'd be looking for a 4x4.
What gear oil are you using? I have 85w140 in my axles and it keeps the lockers quiet, you may want to check the clearances on your locker also, I have installed Aussie lockers before and the only thing you could hear is a slight cliking when going around a corner, but you had to have the radio off and be listing for it to hear it.
Rear wheel drive vehicles just don't go good in the snow.Compound the issue by making one a truck and now you've got a bad/bad situation.A system made to push and a light one on top of it.The best way to fix the issue is to add a front axle and make the poor traction design pull,not only instead but in addition to push.
With the F150's it's actually just all bolt in but since it's not something used often,the best thing you can do is to add weight in the bed.Set a yard of dirt right over the rear axle in the bed.This will aid much more traction in snow more than adding a LS in the rear.Your still left with pushing a light box.Adding weight is near free and fast.Very effective too.It can make your truck go so much better,it will feel like your driving something far different.
Make sure you're running small/skinny tires too.Another good option really,especially if your 2wd is nice and clean as a result of it's poor traction,it probably spent most of it's life off winter roads.A little beater front wheel drive car for winter use is pretty hard to beat.
t
blew his front diff last week
and is now reliving his youth.
eco
03-29-2007 08:23 AM
eco
03-26-2007 02:39 PM
F150newf
09-08-2004 05:41 AM
brokebronco
07-21-2004 02:38 PM
