Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 2017+ Super Duty
Reload this Page >
Thinking about rigging up a 48 gallon gas tank to my truck
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 02-10-2019, 07:20 PM
2019RRSDLARIAT
2019RRSDLARIAT is offline
2019RRSDLARIAT is starting off with a positive reputation.
I'm thinking about buying a 48 gallon gas tank for my truck. It's a junkyard one, so hopefully it should have the lines attached to them. I'm thinking it should fit but the fuel lines could be a problem. A brand new one is $550 and that's a discounted price. The original price is about $810. We are planning on taking a 850 miles trip pulling my 9k lb camper this coming summer so I know the fuel range will be barely 200 miles so it's going to suck filling up 4-5 times and getting about 8-9mpg. I just want a little more range out of it. Here are some prices I found on a used one. I know the crew cab long beds gets this tank standard but there has to be a way.
I'm think about giving this a try. I most likely have to get another fuel pump for it also. I've done a 23 to 36 gallon swap from when I had my 17 F150. I took some measurements and it should fit and clear everything.
Old 02-10-2019, 07:25 PM
Joe T
Joe T is online now
Joe T is starting off with a positive reputation.
Titan makes a 55 gallon tank. Search my threads to find the one I posted about it and it lists some vendors.
Old 02-10-2019, 07:55 PM
7591250sd's Avatar
7591250sd
7591250sd is online now
7591250sd is starting off with a positive reputation.
I just drove 3800 miles pulling out 5ver, and averaged 7.5 mpg, I was concerned about range also, we had our 2 dogs, and they needed a potty break as much as tank needed filing, so worked out fine.
Old 02-10-2019, 08:32 PM
ssunit1's Avatar
ssunit1
ssunit1 is offline
ssunit1 has a good reputation on FTE.ssunit1 has a good reputation on FTE.
In my ‘15 f250 I had a 24 gal tank. Had a major issue when pulling my 5th wheel. Put in a 33 gal aux tank, gravity fed. Problem solved.
Old 02-10-2019, 10:34 PM
Section179
Section179 is offline
Section179 is starting off with a positive reputation.
Best of luck and keep us posted. Maybe the gasser will have room without the DEF.
there red was one dude that rigged up a tank where the spare tire was, but other than that there are no examples of success with enlarged tank on a gasser. If you figure it out Iíll be right behind you...
Old 02-10-2019, 10:43 PM
2019RRSDLARIAT
Well my truck is a gasser so it should be a little easier and more room. If I bought the diesel, I probably wouldnt be doing this upgrade since it gets better fuel mileage anyway.
Old 02-11-2019, 08:25 AM
xxxsherpa
xxxsherpa is online now
xxxsherpa is gaining momentum as a positive member of FTE.xxxsherpa is gaining momentum as a positive member of FTE.
Just to be clear here...Is your truck a '19 6.2 short bed with the 34 gallon tank?
Old 02-11-2019, 08:39 AM
2019RRSDLARIAT
Yes it is.
Old 02-11-2019, 09:17 AM
jstiltner
jstiltner is offline
jstiltner is starting off with a positive reputation.
I took a look under my 6.2 CCSB last time I changed the oil and it looks like there would be room for at least 15 more gallons in the area where I think the def tank would otherwise be. I remember thinking that they should have made the tank bigger.
Old 02-11-2019, 09:38 AM
FastTaurusSHO
FastTaurusSHO is offline
FastTaurusSHO is starting off with a positive reputation.
Do it!
Agreed that there is lots of unused room under the SB crew cab. I don't know if the 48 gallon will fit, but I know more than 34 gallons will. We 6.2 owners don't have the DEF lines, tank, pump, heater, etc. etc.
Old 02-11-2019, 09:45 AM
wrvond's Avatar
wrvond
wrvond is online now
wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.wrvond has a very good reputation on FTE.
A friend of mine bought the 6.2 CCSB and complains about having to stop for fuel too often. It really twists him up when we drive down to South Carolina together. With my 6.7 CCLBDRW and 48 gallon tank, I don't have to stop for fuel until we actually arrive at our destination. Switching to the 6.2 myself, and though it won't go as far on a gallon of fuel, I'm still sticking with the CCLB so I don't have to stop so often (among other reasons).
If you manage to shoehorn a 48 gallon tank into a SB, that could be a real game changer. Good luck!
Old 02-11-2019, 10:00 AM
mhoefer's Avatar
mhoefer
mhoefer is online now
mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.
A stock long box 48 gallon tank will not fit between axle and underside of the the cab. It’s just too long. Your best bet in transfer flow and Titan. The downside to the Titan under bed is how far below the frame it sits. You also have to be careful you have the certifications for gasoline vs diesel. I too would look for a secondary tank where the spare tire sits. So you don’t take up space in the box. I don’t believe gravity feed is allowed, so a pump and electric opening valve as in some of the other threads would be safer.
Old 02-11-2019, 10:28 AM
2019RRSDLARIAT
Originally Posted by mhoefer View Post
A stock long box 48 gallon tank will not fit between axle and underside of the the cab. Itís just too long. Your best bet in transfer flow and Titan. The downside to the Titan under bed is how far below the frame it sits. You also have to be careful you have the certifications for gasoline vs diesel. I too would look for a secondary tank where the spare tire sits. So you donít take up space in the box. I donít believe gravity feed is allowed, so a pump and electric opening valve as in some of the other threads would be safer.
Really?? It looks like it has more than plenty enough roon.
Old 02-11-2019, 11:42 AM
Section179
Hereís a thread in the gasser engine forum some of us have been chatting about this in:
https://www.ford-trucks.com/forums/1...l#post18338944
per the last post the long bed tank is 77Ē long.
i donít think the issue will be overall length, but rather the shape and strap points. You definitely couldnít use the long bed tank strapped at factory points as it would interefere with the rear axle as noted by the above poster.
if you figure this out, or want to go in on a small-run custom tank for ccsb gasser, Iím in.
Old 02-13-2019, 06:41 AM
dnewton3
dnewton3 is offline
dnewton3 is gaining momentum as a positive member of FTE.dnewton3 is gaining momentum as a positive member of FTE.
I, too, want to know. I have a SCLB, so I do wonder if the "big" tank will fit under mine. (I would think a CCSB and SCLB offer about the same amount of space).
Detailed pix are a must, should this actually work out.
I will buy the first round of beers for whomever accomplishes it and does a decent documentation write-up!
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
