1994 7.3 Zero Oil Pressure
what kind of oil was in it? I currently have half 15w40 half straight 40 and its been just under or over 40 below here lately, and no issues but I do plug in the block heater.
maybe something is wrong with your filter ? Maybe change oil and filter before anything else. I'd assume just about any 15w40 would work fine
New filter is on my front seat.
I've seen a few sucked apart...usually the orange Fram.
I have a NAPA filter on it now. Will look inside it, like I do all oil filters I take off.
Also -40f!?
Feel for you!!!
and yes -40. Got a new block heater though and fires up instantly as long as its plugged in a few hours. Oil pressure a second or 2 after firing, zero issues I can tell of
Received 3,090 Likes
on
We've been at or below -30c here for 3 weeks, I run rotella t6 5w40 full synthetic and have never had an issue starting. plug the old girl in and even on the one morning of -45c she fired right up on the second crank. I would never run conventional oil are these temps.
Glad you got her lubed up.
What's wrong with conventional oil? I've always used conventional oil and sometimes even some straight 40 mixed with 15w40 or I'll use 15w40 and top up with 40 weight.
If the block is warm to the touch from the block heater, I don't see the issue.
I've never had an oil pump failure or anything like that. Engines have all been in good condition as well when I got rid of them.
on
If you drove a mile with zero oil pressure, the motor would have been trashed.
Maybe your regulator stuck and you were only seeing a few pounds, or your gauge was faulty.
Starting is the hardest thing on an engine because of lack of lubrication, so I don't see how it would have survived that, not to mention the lifters are hydraulic and it would have ran like absolute garbage popping out the intake and exhaust.
Glad to hear its all cleared up now!
Was running on about 5 cylinders and actually locked right up....completely!
I thought she was a gonner.
Drove about a mile with a 9 ton trailer and it was idling while I loaded the machine so I didn't hear it happening. I wanted to punch myself in the nuts!
Still can't believe it runs.
lllateralus
1999 to 2016 Super Duty
03-01-2012 02:05 AM
Speedmanz
13
10-31-2003 09:10 PM
