Fuel pressure sender - Ford Truck Enthusiasts Forums
Old 02-10-2019, 02:38 PM
Rod Jr.'s Avatar
Rod Jr.
Rod Jr. is offline
Rod Jr. is starting off with a positive reputation.
Has anyone used the Auber fuel pressure sender? If so which one. They have two different senders listed on their site.
https://www.auberins.com/index.php?m...roducts_id=271
https://www.auberins.com/index.php?m...roducts_id=149
Old 02-10-2019, 05:55 PM
bismic's Avatar
bismic
bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Do you expect more than 75 psig? If so, go w/ the 100 psig sending unit. I don;t see over 75 psig on mine, but not all systems are the same.
Old 02-11-2019, 01:54 AM
87crewdually's Avatar
87crewdually
87crewdually is offline
87crewdually is a splendid one to behold87crewdually is a splendid one to behold87crewdually is a splendid one to behold87crewdually is a splendid one to behold87crewdually is a splendid one to behold87crewdually is a splendid one to behold87crewdually is a splendid one to behold87crewdually is a splendid one to behold
I like having a gauge read in the middle of the senders operating range so nearest to that would be the 100 psi unit.
I normally run 68 psi. but have seen it spike to 85 during use.
Old 02-11-2019, 02:10 PM
MTlariat's Avatar
MTlariat
MTlariat is offline
MTlariat is gaining momentum as a positive member of FTE.
From an instrumentation standpoint, IMO sensors and other electronic devices are not necessarily linear in their responses to inputs. They may have significant error readings in the low and/or high ends of their ranges; therefore, it is best to go with a mid-range reading at the normal operating range.
Old 02-11-2019, 02:32 PM
bismic's Avatar
bismic
Error is typically quoted as a % of scale, but regardless, a few tenths of a psi on fuel pressure won't matter a hill of beans. In fact a few psia probably won't matter. As long as the pressure doesn't exceed the range, it is all personal preference.
Just as long as the fuel pressure is 50 psia or better at all conditions (including WOT) and that the gauge and sensor have room on the high side to see an abnormally high pressure that might be coming from an injector back pressuring he fuel system with combustion gas.
Old 02-11-2019, 11:21 PM
Rod Jr.'s Avatar
Rod Jr.
Rod Jr. is offline
Based on the info received probably should go with the 100 psi sender that would read in the middle of scale.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
