What is this part? Pics attached
68 390.
I removed the breather on passenger side. Had a hose going to back side of carb. From what I saw that's the pcv. I'm replacing the breather. Can I replace the hose with heater hose or something or does it have to be specific. The drivers side was missing the oil cap/breather...I looked it up and a hose suppose to go to the air cleaner. I'm missing the air cleaner as well
Rubber valve cover gaskets should I use gasket dealer or no. I want to run the engine today but dont wany to wait for the gasket **** to cure
the parts in the picture I'm not sure what they are but I'd like to replace them. Top left corner.
so it looks like one goes to your brake booster, one goes to your carb spacer, and i would just cap the other one if it doesn't go to anything.
Besides the booster hose, I think a vacuum line from the carb to the dist is all I have on mine. Some models had vac lines that ran to the snorkel. It operated a small metal flap (or valve) to let heated air into the snorkel and the breather. This aided in a quicker warm up. (A small step into the emmisions world).
I looked at mine, and it seems mine just has the one hose that goes to the brake booster. I believe it is just a vacuum port, and it looks like a previous owner has added some extra parts to it for some reason. I would just remove all the extra fittings, and connect your brake booster up to the port. Worst case scenario, you can always put it back.
It's always a pain piecing together parts when you never got to see how it was before taken apart.
