Forensics of my 2003 Ford Motorcraft Remanufactured Motor
#31
Well Jack i certainly watched to the end. And i learned alot so thank you very much for creating such a well thought out video of your situation.
Not alot of folks can bring it all together like you have done and that goes for all your videos.
And im sure any 6.0 owner can feel your pain with so many issues going on at the same time.
#32
I'm debating that right now, Bill. I've never in my life run into an issue where journals were mis-ground, or maybe they were but I never had the need of checking for that. My first hand experience of watching the process decades ago was the journal was indexed off itself, then ground undersize and true. I'm not sure how other then punching in on a CNC grinder you would correct the situation.
But the other situation as someone else has noted, how critical is this or common? This motor wasn't as smooth as the OE motor, but that may have been due to the connecting rod bearing rather than an imbalance created by the amount of journal offset. It's a more questions than answers situation with one 6.0 under my belt. And I'm already expending way more money into this motor then I ever thought of. So I'm getting lost in the cost/benefit analysis with a rusting truck.
I'd fight thru it -- since I just got a bad case of sticker shock visiting the Ford, Ram dealers pricing up new diesels --- $65K or so and frankly the Ford 6.7L is one bloody rats nest of plumbing, electrical................Cummins not so much........If I could only put the Cummins motor in a Ford chassis.............problems solved.............
Isn't the 6.0 B50 for 200K or so miles ((300K for the VT365)...............
#33
#34
Wow. The issues you uncovered certainly are a travesty. I hope that there was or will be some form of financial compensation. You are certainly owed it here.
The expression “Put together on a Friday at 4 o’clock” would have sufficed for the bolt in oil cooler sump. I don’t have the vocabulary to express what I feel after seeing the myriad of other issues you found on a single engine.
sorry man! Thanks for your contribution here. I have learned a great deal from you!
#35
I just now watched the entire video, all in one sitting, all the way to the end, despite having other pressing matters hanging over my head to attend to.
"Forensics" is an apt term, because the way Jack develops his points and conclusions is lawyerly layered, where a base layer of necessity and importance is introduced first, then the facts of the matter are established, supported with corroborating evidence, which then allows the viewer to connect the dots and arrive at a conclusion. This carefully constructed communication is well calculated to be convincing, without being contrived. It is best absorbed without interruption. It is calmly and deftly delivered with understatment, rather than hollered with hyperbole.
In short, it is a typical Jack video... excellently executed.
#36
#37
#39
Making Pandora into Phoenix.
Dressed the decks (video almost ready)
Dressed the heads (video in works)
Dressed the crank (video in works)
Stage 2 cam polished and installed with new bearings (video in works)
Reassembled the bottom end (video in works)
De-rusted/cleaned the cooling jackets (video in works)
Reduced highest protrusion pistons (video in works)
All exterior assemblies painted (no video)
All hardware dressed and painted (no video)
Engine and FiICM electrical harness re-wrapped (video in works)
Exhaust manifolds painted need to be wrapped (video in works)
TBD
Deciding if I want to test pressure of head to block gasket contact (FujiFilm and/or carbon paper).
Bolt on heads
Build coolant vent lines
Assembly remaining parts to block
Each step is held while compiling video to try to make sure I have everything (something is always skipped)
Or if frustration gets the best of me, boat anchor or lawn art.
Looks like can't add pictures tonight.........
TBD
Bolt on heads
#40
#41
#42
Very much looking forward to the upcoming videos Jack. After DieselTechRon's passing there's been a void of informative, well thought out, and helpful 6.0 videos on YouTube. It's refreshing to see someone put in the effort to the benefit of others so thank you.
Curious if during the teardown process you happened to get a value on how much torque was required to turn the engine over or if that's a spec that exists somewhere out there. Currently dealing with a crank no-start unless plugged in (rpms under 150) and wondering if after I eliminate all the usual suspects and it comes down to internal engine resistance if there's a quantifiable spec I can use to measure against.
Hoping you get the truck back together soon.
#43
With the already >100K pricing of new trucks these days, and with hybrid and electric mandates on the horizon, and with the predicted exponent of inflation, expect to also remove 200K from the bank account.
#44
Not that I'm making any excuses for this, but I want to clarify a bit. Ford sells these and markets them as Ford remans. Ford does not reman ANY engines. All remans are outsourced.
There are a handful or reman companies around that periodically bid on doing Ford's remans. Knowing what I know about how they outsource things, cost is no only king, it's about the only thing considered. Ford won't go with a reman company that shows them they do better work than the others if they cost more than the others. I don't know who did the 6.0L remans.
#45
Mark,
I do understand the situation, and understand that you are only trying to clarify. I indemnify you from any of this.
But Ford markets and sells the product. The brochure instructs the customer that the product it is selling is better than other companies and in fact names Jasper as a competitor. Jasper during some periods of time may even be the supplier of Ford remans, but in this case, I'm expecting it to be CAT. If a product with some semblance of quality can't be sourced, especially at this pricing level, then Ford should just tell the customer look elsewhere. Giving the impression that it is a higher quality product in the marketplace doesn't fit in my book of ethics.
At the time of purchase this was a hard financial hit, but my making. . I made a bad choice believing something that was not true, after having a full career in the automotive industry. For someone who is standing at a service advisor's station who maybe can't change his own oil, this is criminal at this cost and quality.
Overall a good example of how to take a problematic situation (International's motor) and make it even worse.
Last edited by TooManyToys.; 02-15-2019 at 02:57 PM. Reason: Removed personal points in the argument.
