I'd say you have identified your problem for sure.
Still baffled by the stuck injector.
I would be worried that now that O-rings and copper seal have been disturbed you will have leaks. Could end up with mixed fluids and low HPOP pressure.
I knew about the connector problem straight up but figured may as well check every thing while we were so far in. The # 8 is a worry and I want it checked before refit, then I will check the other bank. Thanks for all your help, really appreciate it.
1 thru 7 should be the same, although the solenoid colors can be different if they are not original. #8 is the "long lead" injector intended to quiet the cackle. You can swap in a regular one with no issues.
Finally got the # 8 out, lifted the rocker and it slipped straight up. Have carefully replaced all the O rings and cleaned the injectors up. Removed the glow plugs and the ends are a bit brown due to heat, should I give then a gentle wire brush treatment before they go back in? Also I would like to retest the plugs and injectors as they go back in, what's a simple way to test without special tools, use a test light for the plugs but not sure about injectors. Got the new gasket and harness readt to go as well. Aussie Bob
To all you guys that sent me experienced info, the truck is back together and running like new. I am so happy to deal with honest people that want to help, what a great team and site!!!! F250 rides again!! now for the next 270000 kilometres.
Bob, glad you're up and running again. You did all the work and we're just happy we could be of some assistance. Thanks for being part of the brotherhood.
Due to the job being easy when you follow the rules I will be doing the other bank shortly.
I see you have air bags I ma looking at them to make my ride safer under load.
I got the airbags when I had a center console boat that set a little heavy on the front of the trailor. Leveled the truck up when towing. I learned early on though not to leave them aired up when not towing. Back end of the truck bounces badly.
