No electrical at all
Old 02-09-2019, 05:58 PM
LittleLucy
LittleLucy is offline
LittleLucy is starting off with a positive reputation.
I replaced the belts. No power AT ALL .....no dome light .....nothing
took voltage on both batteries . They're sitting at 14.....tried to check grounds etc....
it's freezing and a foot or more of snow..
any clues?
I'm thinking something got loosened or disconnected , what have you
I reeeeeally needed my 4x4 beast in this weather that is supposed to stay around for another week
help help
please
Old 02-09-2019, 07:18 PM
seville009
seville009 is offline
seville009 has a good reputation on FTE.seville009 has a good reputation on FTE.seville009 has a good reputation on FTE.
Did you have power before you replaced the belts?
if you did, then check the replacement belt, of course. Also check all of the connections around where you worked to make sure a wire/connection didnít come loose or is broken.
i assume the truck must be running if youíre getting 14 volts
Old 02-09-2019, 08:22 PM
LittleLucy
I'm an idiot
I actually had 2 v on both batteries
I'm assuming it's because the alternator belt was going so not charging :/
I have charged up the batteries now and the glow plug relay isn't working
no noise from starter. But I have dome light etc.
ugh
I'm fairly certain that it's the frozen tundra
one battery is new gotta wait until payday for second new battery
I know I know
I'm supposed to do both but......
Old 02-10-2019, 01:37 PM
parkland
parkland is offline
parkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud of
ugh
I know I know
mixing a new battery with an old but good battery isn't a good idea but would work for a while.
mixing a crap battery with a new one is a waste of time and money. Wait till you can buy 2 batteries.
Old 02-16-2019, 11:24 AM
'88 E-350
'88 E-350 is offline
'88 E-350 has a very good reputation on FTE.'88 E-350 has a very good reputation on FTE.'88 E-350 has a very good reputation on FTE.
You said you have 14 volts, then said 2 volts; which is it?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
