Smog Delete?
Old 02-09-2019, 04:03 PM
RageOfAntioch
RageOfAntioch is offline
RageOfAntioch is starting off with a positive reputation.
Smog Delete?
Hey guys
Pulled the engine on my 1984 Ford F-150 2wd 302
And before re-installation i was looking to delete the smog pump
Is this a good or a bad idea? I was planning on running hooker headers and hooker exhaust and I have a Edelbrock Performer 289 and A 4 barrel carb
What will I need
And what vacuum lines will be left over and where will they run?
Old 02-09-2019, 06:33 PM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is offline
FuzzFace2 is a name known to allFuzzFace2 is a name known to allFuzzFace2 is a name known to allFuzzFace2 is a name known to allFuzzFace2 is a name known to allFuzzFace2 is a name known to all
I don't remember does 84 need to go thru smog check up there?
If not then you can remove everything, smog pump, EGR, cats.
You only need the dist. vacuum advance, PCV, brake booster, HVAC and maybe the charcoal canisters to keep gas fumes from getting into the cab.
Dave ----
Old 02-11-2019, 06:49 AM
Odisvan
Odisvan is offline
Odisvan is starting off with a positive reputation.
beware if you have AOD trans how to adjust pressure for other carbs than stock 2 barrel.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
