Have in shop steering cylinder off 1982 F7000 that customer beat on thread end. Cylinder is marked D6TA 3A540 AA with cyl rod end marked 403804 425 . Do not have front axle code, Also is rod avaible , it is 11/16. We have 5/8 and 3/4 chrome rod stock.
Do not have front axle code, Also is rod available, it is 11/16. We have 5/8 and 3/4 chrome rod stock.
I looked for a pic of the cylinder, couldn't find one. Then I crossed the D6TA-3A540-AA ID number to the part number D6TZ-3A540-A and looked up its application.
You are working on an LN series, not an F Series. I need the AXLE code printed on the Certification Label to find out what the weight capacity of the front axle is.
Lower pic: Here's the 9,000 lbs. capacity cylinder. The other cylinder looks completely different.
Thanks ND That looks like cylinder that I have. I am going to get customer to get axle code Monday. If this is correct cyl will need 3A533 , 3B711 , 3B542.
Thanks ND That looks like cylinder that I have. I am going to get customer to get axle code Monday (EHN).
This is the correct cyl, will need 3A533, 3B711, 3B542.
.C8TZ-3A533-A .. Ball Stud Repair Kit - Mounting End - Kit includes C8TZ-3B711-B Ball Stud / Obsolete
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1 = 800-476-9653.
RPN PARTS in Erie PA has 2 = 888-864-9305.
NOS PARTS LTD in Waxahachie TX has 3 = 972-937-2201.
GREEN SALES CO. in Cincinnati OH has 11 = 800-543-4959.
-------------------------------------------------------------------- C8TZ-3A533-B .. Ball Stud Repair Kit - Moving End - Kit includes C8TZ-3B711-A Ball Stud / Obsolete
MILLER OBSOLETE PARTS in Vestal NY has 2 = 607-722-5371.
GREEN SALES CO. has 6.
---------------------------- D6HZ-3B542-B (replaced C8TZ-3B542-A) .. Cylinder Piston Rod ~ 3/8" -24 and 11/16" -18 x 14 7/16" long / Obsolete
No Ford dealer or obsolete parts vendor has any.
------------------------------------------------------- C8TZ-3B542-A
