I wrapped my front bumper
#46
Does the vinyl wrapping cause the chrome underneath to deteriorate faster? I know the reason to cover it up is you don't like the look, so who cares. I am thinking if it results in corrosion, it would weep rust stains and cause the bumper to look crappy that much faster?
Those wrapped bumpers look really good!
#47
#48
Thanks had found a good price on matte on amazon but not the gloss. Tried that fellers website and they offer it in 5' x1yard pieces. Waiting to hear back if I order quantity of 4 if itll be one large continuous 4yard roll. Would be useless in 1 yard as that's not enough to do the front bumper unfortunately.
Thank you, waiting for sign mart to approve account so I can even see their pricing. Sign warehouse seems to sell minimum 25yards for $333. Which isn't a bad price at all but way more than I could ever need!
I hope OP was right and 090 is an exact ingot silver match I'm blind buying based on that 😉
#49
tricon, do you have experience in the field with vinyl by chance? just ask, because it looks like you did a really good job and vinyl wrapping is not easy. I was in the sign business for years and the company I worked for specialized in vehicle wraps but they mostly used 3m 1080 vinyl. bumpers were always the problem areas in vehicles with the vinyl peeling back up. in the fog light areas the installers would use a 3m primer for better adhesion. in those corners where the vinyl tends to wrinkle a little often lead to failure.
oracal film tends to be pretty aggressive film in regards to adhesion, so once it was down it was tougher to pull back up to rearrange if need be.
avery film was the lower quality vinyl.
3m 1080 (pricey) was what our shop used mostly but I think they have even higher quality products now as I have been out of the business for awhile.
geek wrap squeegee's were used in our shop, pricey but very nice and had a cloth side that was less likely to tear the vinyl.
good prep is key. all surfaces should be cleaned and then wiped down with alcohol prior to installation. a clean work area is also key as the film draws a lot of static and can pick up lots of debris, which will stick out like a sore thumb under the vinyl. also note, if you are doing this outside on a hot, sunny day, the bumper will heat up and it makes install more difficult. the vinyl reacts to heat, which is why special heat guns are used or experienced users use torches.
fellers was always the most expensive in the industry unless you were buying quantity, not sure now. another place to look would be grimco, they have stores across the US and ship.
I am in no way trying to say that no one should try and do this themselves, but I hope that they know it is not necessarily easy, like slapping a sticker on. just my 2 cents, for what it's worth, hope it helps. good luck to all.
#50
I've never touched vinyl other than putting graphics on MX bikes....and I am in no way saying this is an easy endeavor. I spent like 6 hours on this bumper positioning and repositioning it. Its my understanding that car wrap vinyls have come a long way in the last couple years. This ORACAL stuff was pretty forgiving, if I screwed up and and got it all wrinkled or what they call "crow feet" I just pulled it up and hit it with the heat gun for a couple seconds and all the wrinkles would fall out and I tried again. I must've done that hundreds of times, but once it was down it would stay down unless I really pulled it up.
Do not try this if you do not have the patience of a saint.
That's also why I suggested people try the grille or rear bumper first. You'll get a feel for how the material works and those surfaces are a lot flatter/easier to work on and with less material. Doing the front bumper was like jumping into the deep end, I knew it was going to be hard, but I was determined, and it came out great. There's some screw ups in there if you look really close, but from 2 feet away it looks like a platinum painted bumper. To me, its worth the $60-100 and a saturday afternoon...I enjoy jumping into new things and figuring them out. If that's not you....you'll be smoking cigs by the end of it.
One of the guys here said he paid $250 to have the bumpers wrapped, I would gladly pay that if I could. I was quoted $600-700, so for 10% of that it was worth giving it a shot.
#51
again, that is impressive for first time and I hear you on the patience thing. I never had any interest in that area of the sign business as my ADD would kick in and I would be bored.
#53
ended up making order from fellers. $142 after taxes for 60"x4 yards and a applicator.
#54
Sweet, let us know how it goes! Take your time, and don't be afraid to step away and grab a beer or four I found that if I got frustrated at some points I'd come back 10 minutes later and it would just go right down the way I wanted.
#55
#56
#57
#58
Off topic...is there a vid to remove the chrome caps on the rear bumper? Might be a project I could do in mean time if it's simple enough to remove them.
#59
