91 e4od transmission pops into neutral at 27 mph
I hate to see you go. You are very entertaining. An imagination like that is a terrible thing to waste. We get so many sheep in here these days. You are not a sheep. You are a thinker. Just be a little more careful with those wire cutters.
Wouldn't 27mph be right about the TC clutch lock up point?
OP, thicken up your skin. Just saying that you "cut wires" does sound hack. Did you ID what you were cutting?...I hope.
You can get the pcm to control just the trans with the right wiring/sensors. Or,by installing an after market trans controller,either way will be cheaper/easier than a C6 swap.
rucountry
12-09-2011 04:59 PM
mrmilkme
01-19-2005 07:04 PM
