The infamous 6.2 Ticking noise
Guy I am lost, there is so much I have read about the 6.2L ticking noise. So many causes and so many people saying it’s normal. I just don’t think it “normal” if I can hear it; even faintly, from inside the cab then something isn’t right. Ok so I heard it from the first time this morning. 27 degrees, would have an rpm following tick until 1500 rpm then it goes away. Non tempature specific. Drive ability is perfectly. Fuel mileage is normal, trucks runs normal, and it only happens at idle in part. Sound like it is coming from the center of the motor under the intake. Truck is a 2017 with 60,000 and a 5w30 ford job on it, certified pre owned with full warranty until 100,000. Just want to go to the ford house prepared with knowledge. What’s your thoughts! And yes blinker fluid is full and wiper pressure has been checked.
I know I had a slight exhaust tick all along but it just seems to sound more matallic sounding almost like a hammer on plastic than exhaust sound. I have not seen anything that could be making the noise so far. When I say I can here it in the cab I can just barely hear it. It’s so faint but I can hear it. Hoping not a flat spot on a cam or Gawled up roller
Fair, but getting a check-engine light at 1500 miles that forces you to pull off the road due to limp mode is not exactly confidence-inspiring :P .
Agreed. And now the dealer has something they can verify and work on. Better than hearing "we can't duplicate the issue"
