Questions about VIN location and data plate
Old 02-07-2019, 03:59 PM
phil64's Avatar
phil64
phil64 is offline
phil64 is starting off with a positive reputation.
Ok, the truck was imported by my daughter.
When i read "tre truck is an import" i understand as in the french sentence: "this car is an import" => implied (in french) the car was imported and sold new by the manufacturer.
Old 02-08-2019, 09:57 AM
ctubutis's Avatar
ctubutis
ctubutis is online now
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Remove the dash pad, the plate with the VIN can possibly be bent back a bit to get some clearance and a better field of view.
Old 02-08-2019, 12:46 PM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is offline
FuzzFace2 is a name known to allFuzzFace2 is a name known to allFuzzFace2 is a name known to allFuzzFace2 is a name known to allFuzzFace2 is a name known to allFuzzFace2 is a name known to all
I don't think that will work as the opening in the glass to read it is off set to 1 side.
You either have to move the opening in the glass to line up, not going to happen
OR
move the VIN to line up with the glass opening, also not going to happen.
The only thing to fix this as said is to get the right glass with out the boarder, non-glued in glass.
Dave ----
Old 02-08-2019, 01:51 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
I'd place a mirror on the inside of the dash opposite the VIN tag, then take a few close up pics.
Removing the padded dash could cause it to crack, buying a w/shield in the US then having it "shipped across the pond" will be very expensive, maybe give-or-take, 1500 Euros.
Then you have to find someone to remove the old windshield, install the new windshield...that glues to the body. Not pleasent!
Old 02-08-2019, 03:08 PM
phil64's Avatar
phil64
phil64 is offline
I'll try to take some pics with a mirror and a light, i think it'll work !
Maybe i'll try the ctubutis méthod, i must remove the dash pad to change a bulb and it's a thing i've done several times ...
Old 02-09-2019, 04:04 AM
FuzzFace2's Avatar
FuzzFace2
I got to ask what bulb you have to change where you have to remove the dash pad?
Anything in the gauge cluster you remove the cluster and the heater control you remove the control panel IIRC.
Dave ----
Old 02-09-2019, 04:26 AM
phil64's Avatar
phil64
phil64 is offline
Oups, I wrote anything ! I never removed the dash pad, only the cluster ...
Old 02-09-2019, 05:22 AM
FuzzFace2's Avatar
FuzzFace2
LOL that is OK just wanted to make sure you or anyone else that reads this was not pulling the pad to replace bulbs.
Are you still running the colored covers with the stock bulbs?
The colored covers can turn to chalk and not let light thru.
What some do is remove the covers and use LED bulbs in a color they like.
Some like blue others red, me I like the green as it is close to factory color and it matches the heater control panel & head light / wiper switch lights.
I left my colored covers in as they were in great shape from when I had the cluster apart for cleaning & needle painting about 6 months ago, some bulbs did not work and why I pulled it and went LED's.
Dave ----
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
