F450 rear shocks
F450 rear shocks
I have waited way too long to replace the stock 'Ranchos'--been reading thru old threads to find a choice. Truck is stock, don't need anything for off-roading and such, just a good replacement for the old ones. Guess the only option is a Rancho9000XL adjustable? Trying to get Les Schwab store to find a fit--their listed KYB MonoMax did not. Any help?
EDIT: Got the 9000XLs and tried them for fit----the bottom of the shock does not match the OEM and if the steel sleeve is used, the bolt does not fit. What is the deal to get the 9000 installed on the rears?
Tried the Rancho number--answered by Tenneco after about 4 mins holding. Then the guy could not help, says the number shock I have (999273) is the correct shock, but the bottom mount/bushing is different than OEM. Any help?
While Summit doesn't know that the F450 uses the same shocks as the F350, you'll notice the part number for a 2017+ is RS999047A instead of the RS999047's that you probably have. Amazon has the wrong info.
https://www.summitracing.com/parts/r...350-super-duty
BTW, I sprayed a couple of coats of clear on them and put grease in the adjustment pin (under the ****) to keep them looking good and adjustable longer.
2009kr,
Thank you for the numbers----Rancho themselves (Tennneco) said the correct # was 999273. Will talk to installer tomorrow and see if he can get them.
These are for a stock height 450, not lifted, right?
someday,
Don't feel good about that--just like don't feel good that the supposed correct shock bottom mount doesn't match the OEM, but thanks.
someday,
mgpsfan,
Thanks, and I will use them to see what I get. I also talked to Rancho Support and he insisted the correct shock for the rear of a 450 was the 999273, but believe he was not smart enough to know anything but what his papers said, could not accept that it did not match the OEM.
More confused than ever--Rancho distributor for Les Schwab says the 999047A is special-order and each one is $50 higher than the 999273 that Rancho insists is the correct one.
Going to give up on replacing them til I am in a RV campground for a month and begin again to research fitments. Full-time in fifth wheel and don't feel good about Rancho giving out info conflicting with correct shock number. Can't get real info from website, just lists tons of shocks and no particular application.
Thanks all for trying to help,
Joe
Joe
Received 6,659 Likes
on
Joe
Joe
I used the same Bilstein shocks for an F350 on my F450, even on my '15 F450 - physically the same. So, the Rancho should physically fit. However, the Bilstein shocks require a bushing replacement or drilling out the sleeve to fit. The Rancho seems to have a direct part number followed by an "A" which has the larger 9/16" sleeve size to accommodate the bolt.
