Idi fuel economy configuration
Old 02-07-2019, 07:02 PM
hairyboxnoogle's Avatar
hairyboxnoogle
hairyboxnoogle is offline
hairyboxnoogle has a good reputation on FTE.hairyboxnoogle has a good reputation on FTE.hairyboxnoogle has a good reputation on FTE.
Originally Posted by RaymondIV View Post
The theory from the big boys (factory engine reps) has always been that a turboed engine consumes 1/3 more air than non turboed. ATS with their turbo kits included a complete 3" exhaust versus 2 1/2". They stated in their info with all their R&D that an exhaust bigger than 3" showed no power gain at all.
Its more than a 1/3, at 14.7 psi (at sea level, less as you go higher) youre using DOUBLE the air. Banks had a similar claim, stating that going from the supplied 3" to the "monster" 3.5" exhaust netted about 5hp at 3300 rpm. When i was running my 088, it had 3" with a glasspack (crush formed), when i replaced it with 4" mandrel from the down pipe back, i gained like 4-5 pounds of boost at WOT (could hit 18), egts were cooler at WOT as well. This was an 088, with a massive leak in the drive side, and a maxed out 275k pump.
All that said, the fuel specs that ATS and Banks recommended were hardly anything above NA, in that context, the larger exhaust probably wasnt necessary, but 10psi vs 20psi is a substantial difference in air flow, potential fuel burnt, and thus creating exponentially more exhaust.
Old 02-07-2019, 09:03 PM
Macrobb's Avatar
Macrobb
Macrobb is online now
Macrobb is gaining momentum as a positive member of FTE.Macrobb is gaining momentum as a positive member of FTE.
Originally Posted by parkland View Post
I've definitely noticed how linear the rpm is to throttle position. I was very surprised to learn that the pedal is simply controlling the rack. It feels like an rpm governor.
That's because it *is* an RPM governor... though the governor response is 'tuned' a bit low, so it droops under load more and is thus a 'road governor'.
If the pedal controlled the rack, you wouldn't have a governed speed really - it would go much higher until it physically couldn't push enough fuel to maintain that speed.
As it is now, unloaded peak RPM isn't much higher than loaded peak RPM, because governor.
Old 02-09-2019, 09:49 AM
parkland
parkland is offline
parkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud of
would be nice to know what the power gain is at normal rpm, and if it's a power gain or also an efficiency gain.. a few hp at 2000 rpm gained without extra fuel burned would be quite a loss freed up. I'm guessing the actual hp required to push one of these trucks down the highway is probably 40 to 60 hp, a few hp freed up would be a small but noticeable mileage gain.
Old 02-09-2019, 11:47 AM
RaymondIV
RaymondIV is online now
RaymondIV is starting off with a positive reputation.
Back in the day, about 1990-91, there was nothing Banks DIDN'T make a claim about. They had a high dollar non-turbo air cleaner element that we just had to have according to their adds. I phoned their sales pitch line one day and asked how their A/C element breathed better if my Filter Minder wouldn't move when towing a max loaded gooseneck up a steep grade with my stock air cleaner? The sales pimp's answer was downright hilarious. They also claimed their turbo system put out WAY more power than ATS. They failed to mention Banks used a sea level 180 HP 7.3 engine whereas ATS in Murray, Utah used the high altitude 7.3 IDI version that was 160 HP for test results. And when I was researching to death which turbo system to buy, Banks people had nothing positive to say about their own, they just badmouthed ATS up one side and down the other. That's always told me a lot about which product to buy. Especially after Ford chose ATS in '93.
Old 02-09-2019, 01:58 PM
Macrobb's Avatar
Macrobb
That sounds like a failing on ATS's part. Most IDIs were the 180HP version... and, if you crank the fuel up(as Banks suggests), that calibration is lost anyway.
I can't say about the sales info, all I know is that the (wastegated) Banks Sidewinder is, hands down, the best "kit" turbo I have seen run. It spools faster and tops out similarly to the ATS, pushes more boost.
Also, the turbo placement is way better than the ATS - Getting to the #5 and #7 glow plugs with a ATS 093/Factory turbo kit is a real pain.
Considering ATS let Ford butcher the factory kit they used, I'm not sure that's a good reasoning. Now, I understand it - Ford wasn't going to modify the firewall to get clearance for extra piping, but still, I could totally see that being a deal-breaker for Banks.
As a disclaimer, I currently have: 2 Banks Sidewinders(my dad has a 3rd), a Ford Factory kit/093(second kit waiting for a rig), and an ATS 088 kit.
(also my friend has a Hypermax kit on a non-running truck; no clue yet how that performs).
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
