7.3L kill resale value of 6.2L
#256
That's a ridiculous statement. Have you driven the two? I mean, i don't disagree that a half-ton rides nicer, steers better, is quicker, gets better fuel economy, and has better brakes. But the capability is not there at all. I own a side business and have several work trucks. For my personal daily driver, I wouldn't really want anything other than a 3/4 ton or 1-ton truck. I don't care about the trade-offs. I like sitting up higher, not lower...I like larger tires, I prefer to have substantial payload, I want to be able to tow a trailer with a WD hitch and have it feel a lot more stable. I want the greater off-road capability of the HD truck. I want to be able to carry and push with a large plow. And this is coming from a Raptor owner! I just like the feel of an HD truck.
Gas or diesel HD trucks are fine. Most guys that are doing "real work" use gas powered HD trucks. They are cheaper to buy, cheaper to maintain, and have more payload. The only commercial guys I see running diesels are those who really need to tow something heavy.
I've had both. I like the diesel better. But the gas engine is completely fine, and I'm talking about the 6.2L. The 7.3L will be even better.
Just as an example sitting at the ranch in 110 temps the Raptor would not blow cold air for an hour or two at a time lol but my 6.7 I have to turn up because it will actually get too cold on the lowest setting using recirculated air which is a must because of dust and dirt out there. Many other things such as handling with heavy load but AC is my pet peeve.
#257
I live in NH...obviously it doesn't get as hot here as what you experience. We had one day last year when the temp was 102F. That's extremely hot for us. My gas truck cooled me very adequately on that day, as did my diesel truck.
#260
^^^^^^^^ I can certainly understand your perspective and respect that. On the other hand I have extensive experience with many vehicles sitting in the desert at well over 100 degrees for several hours at idle at a time. WITH ALL DUE RESPECT you have no idea what goes on under the hood in these conditions unless you have had to do it not to mention sustained winds at 30 to 60 mph. There is a reason out there you hardly ever see 3/4 ton trucks that are gas in the oilfield there and yes see .5 ton trucks all the time for works going to a rig to work for example. The Raptor would not unless you were driving it around blow COLD air even on recirc which is a given out there. After sitting at idle the AC air temp when it was 105 to 110 would eventually go up to 70 or so now the temps would come down to 60 or so if you barely touch the accelerator to force a 11 to 12 hundred rpm idle but that is problematic and a pain. The temps on the radiator would also climb not to overheat but still climb to hotter than normal driving down the highway at 70.
The diesels albeit the Cummins I have had several were good BUT the 6.7 Ford has exceeded my expectations exponentially in this regard. Example of temps is oil. On the road in 110 temps the oil temp runs 210 to 220 at 70-75 or so running empty. Sitting at idle in those same temps it stays around 180 no more. Imagine it also has to do with the compressor spinning speed as well however, this is the first truck I have ever owned that CANNOT be run on max ac and max fan in these conditions because you will be uncomfortable.
You may not buy it but let me know if you are ever going to be in far S/E NM (will be there next Mon-Thurs tomorrows forecast 81 high 20-30 west wind gusts to 40) but it is not going to be hot lol and you can see for yourself. Sometimes that is what it takes to understand something you have never experienced and all things aside on this new gas motor if it does not have the structured cooling system like the 6.7 and just has with the conventional set up like the current gas Ford truck motors I will just have to keep my oil burner. After thinking about this the Cummins I have had 2 different ones out there one the old 5.9 would blow cold to cool after a while but nothing like the 6.7 Ford does.
There has to be someone else on this board that has to idle for hours in high desert temps that has some experience with this.
#261
I've lots of experience with having to idle diesels in frigid Arctic temps just to keep them running and to have any chance at having a warm cab. The Interior of Alaska is technically an Arctic desert - does that count?
#262
#264
The 6.7L Ford has a higher heat load than the gas 6.2L for sure, and actually has a higher heat load than the Cummins or a Duramax. This is why it has one of the most complex cooling systems of any vehicle on the road, as you know, with dual radiators, four thermostats, two water pumps, and two degas bottles...with the primary and secondary cooling systems being completely separated and operating at two different temperatures. The Cummins probably has the biggest advantage because it has the best chance of cooling air flowing down the sides of the engine. But all of this is still irrelevant to A/C performance.
Regarding the 7.3L, you will see a very conventional cooling system with one radiator, one water pump, and one thermostat. The name of the game is reliability and durability. Don't get me wrong, I love the complexity of the 6.7L Ford's cooling system, but it opens up the opportunity for a lot more to go wrong.
#265
I appreciate the cordial conversation. You are talking about two different things - the cooling system's ability to cool the engine vs the A/C system's ability to cool that cabin. How hot the engine's oil or coolant might be is completely irrelevant. You have to remember the truck's A/C condenser is *in front* of all the other radiators and coolers. So whatever is going on behind that doesn't matter. Now, a fan's ability to draw ambient outside air across the condenser is important...and if the diesel truck's A/C truly does outperform the gas truck's A/C then the engine fan would be the culprit and have nothing to do with the engine itself. The evaporator and blower system inside the dash is identical between gas and diesel.
LOL with the gas trucks including my Raptor would turn them into the wind if it was blowing and sometimes open the hood to let some of the heat escape. I know you never have experienced any of this but believe me it happens. This will be my last post on this specific issue hopefully someone else can come along and explain to you why the diesel engine at idle generates so little heat load and it in turn helps the AC systems work better in this specific operating situation. Maybe our friend from Alaska can explain it.
#266
Dave, Dave, Dave...why do you think the amount of heat the engine generates has any bearing on how cold the A/C system is? As I said before...the A/C condenser is located directly behind the grille. All the radiators and other coolers are located behind it. As is the engine which is making heat.
i don't mean any disrespect and I think we're having a good, interesting conversation here.
#268
The a/c on my gas V10 works well even into the 100-110 range. Idling, driving, it doesn't matter. I've been in some pretty hot situations idling for a long time waiting at boat ramps and have never noticed a cooling issue.
I don't understand the issue here unless a truck with low freon is getting compared to a fully functioning system.
Regardless, you can rest assured the 7.3 a/c will work great!
#269
So much depends on:
Option cost of the 7.3
How much more HP and torque.
In a heavy truck you would be hard pressed to notice 40-50 hp and torque by the old butt dyno. More, and you can tell. But what does more cost? Maybe Ford is holding the option hostage to Limited or Platinum levels?
Time will tell.
Time will tell.
lol
#270
Diesel guys love to come into gasser threads and crap all over them.
"Durrr...I have diesel...I have all the torques..Nanna-nanna-boo-boo...I have gooder reseale...durrrrr!"
