69 Ford F100 Best Engine
so it seems i will have to build or buy a new engine. ive been looking onto what to put into it, but what all would you suggest? its a 69 Ford Ranger, had a 360 in it. should i stick with the 360, or put the 5.0 in it? or should i go bigger? i liked the way it use to drive with the 360 in it, but i would mind more power. i am trying to keep it classic, but also have a little muscle and sound great (deep rumble) when i put the exhaust and headers on.
Really is a matter of personal preference on what engine someone likes or has had good luck with but something to think about is swapping in another 360, 390, 428 will be the simplest assuming you want to use the same bellhousing/trans, driveshaft, and perches. Any of them can be made to perform well if you use the right components depending of course on what you want to do with it and what your budget is. I have several 67-79 f100s and I have a couple 5.0 overdrive trucks I could drive anywhere without worry and have plenty of power and get good fuel economy. But my favorite is an all original '79 with a gutless original 302 because I like originality a bit more than performance. Just depends on what YOU like and also on what is available to you in your budget. But I will say that when I go looking for a engine for one of my trucks I always try to find one that is running in good shape preferably a low miler or a low mile rebuild and not one that needs machine work and other bs unless it is something special. Doing it this way you'll be dollars ahead in the end.
It is all personal taste/preference. I like the old FE's, but they are tasty on fuel for the most part.
If I was making a nice driver, I'd find a roller cam 302 with an older AOD. You can throw a lumpy little cam, it will run great, you can put some decent gears in the back to make it run well and the old cable style AOD will make it get really decent mileage without having to deal with any electronics. I'm more of a stick shift person and would work on getting some kind of 5 spd in it, but the AOD would be simple.
gas mileage isn't to big of a concern as this truck will only be a Sunday driver and maybe entered in the truck shows. i have a 2019 F350 that is also a company truck/Personal truck. so i can take my time with this as well as not have to worry about making it gas mileage conscious
