F350 Message Center Buttons not working.
2011 F350 6.2 XL. The message center switch/buttons on the steering wheel are intermittent. Will make contact and work when cool/cold. Do not work when the cab temps warm up. Cruise control buttons DO work in all temps. Have replaced the switch assembly and used contact cleaner on pigtail connector contacts, but problem still exists. Is there a electrical slip ring in the steering column that I could access and try cleaning? Thanks.
