1988 f250 7.3L idi
Old 02-03-2019, 11:09 PM
Tbrad003
Tbrad003 is offline
Tbrad003 is starting off with a positive reputation.
1988 f250 7.3L idi
Iím having smoke come from my dash and donít really now what it could really be, it smelt electrical but couldnít see any burnt wires from just underneath dash. I donít use heat or anything blower motor has been out of it for while now so didnít think that could be it.
Old 02-03-2019, 11:43 PM
DarkOverCast
DarkOverCast is offline
DarkOverCast is gaining momentum as a positive member of FTE.
Pull the radio and take a look.
Once in another vehicle I had the po installed an aftermarket radio and the dimmer wire from the headlight switch which was unused for the new radio, was touching the metal brace..
Old 02-04-2019, 03:49 AM
Tbrad003
Tbrad003 is offline
Ok I will try that when I get off of work today it does have a after market radio In it and has had subs and a light ran in it.
Old 02-04-2019, 07:30 AM
Olds64's Avatar
Olds64
Olds64 is offline
Olds64 is starting off with a positive reputation.
You can also check all of your fuses. If there was a short that caused smoking hopefully it blew one of your fuses. If one of your fuses is blown start with that circuit.
Old 02-04-2019, 06:05 PM
Tbrad003
Tbrad003 is offline
I checked all the fuses and one of my fuses look like it was melting and circuit board may need replaced because of were the fuse melt the slot for it.
Old 02-05-2019, 07:18 AM
Olds64's Avatar
Olds64
Olds64 is offline
That's no good!
Post a pic when you get a chance.
Old 02-05-2019, 07:46 AM
Tbrad003
Tbrad003 is offline
Will as soon as I get off today.
Old 02-05-2019, 04:07 PM
tjc transport's Avatar
tjc transport
tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
when my 88 did that it was the hot wire that feeds 30 amp fuse that powers the Heater blower,. that main power leg splits in the fuse box and powers 4-5 other fuses.
AC, blower motor, brake lights, and a few other things
Old 02-05-2019, 04:40 PM
Tbrad003
Tbrad003 is offline
Tjc
So what did you do to fix that? Did you just remove the hot wire? Replace the fuse box? What were your steps to solve it?
Old 02-05-2019, 05:05 PM
tjc transport
i ain't rite
i removed the smoked wire from the fuse box, and soldered in a maxi fuse holder then connected all the other taps to the other end of the maxi holder. it was only supposed to be a temporary fix until i got home, as i was 400 miles away on a wide load escort.
as with most of my other temporary repairs, it became a permanent repair because it never gave me any more problems. 20 years and still holding.
but when i replace the cab i am going to use the wiring harness in the new cab, as it is uncut and all original out of a truck that only had 23,000 miles on it.
the owners son "borrowed" the truck in 91 and hit a tree. the father backed it into the barn and left it there for 21 years.
my friend bought it for the engine and trans and sold me the sheet metal.
Old 02-12-2019, 12:34 PM
Tbrad003
Tbrad003 is offline
Still smoking
Iíve removed the fuses and replaced the bad ones but the blower moter fuse is obviously to bad of shape to put fuse back in it so I left out and noticed that when Iím turning my lights on itís cause the truck to smoke but I canít locate weíre the smoke is coming from
Old 02-12-2019, 04:15 PM
DarkOverCast
Have you checked the plug on the headlight switch?
They're bad about melting and shorting
Old 02-13-2019, 07:04 AM
Olds64's Avatar
Olds64
Olds64 is offline
I also had a blower motor speed switch melt down. I don't know if it's the rattling cause by the diesel engine or just poor engineering, but the wiring in our trucks strikes me as pathetic.
Old 02-13-2019, 12:36 PM
Perk85F250
Perk85F250 is offline
Perk85F250 is starting off with a positive reputation.
The blower motor has excessive current draw and is the cause of the circuit and fuse meltdown. The motor needs to be replaced. I have done the fuse bypass as mentioned by TJC Transport with with good results.
Old 02-22-2019, 12:49 PM
Tbrad003
Tbrad003 is offline
The Wires seem pretty shot so I am replacing the pigtail switch in the main headlight switch but noticed this green yellow wire as burn all the way up to the wire harness
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
