Electronic Parking Brake ?
Because cable actuated parking brakes and/or the cam/actuator at the drum were never known for getting stuck? Just look at the Ranger recall ( already ) "The Problem: The shifter's bezel wiring may interfere with the shifter interlock override, preventing the shifter from locking in Park and allowing the driver to shift the transmission out of Park with the truck off and without a foot on the brake pedal, increasing the risk of a crash." completely reiterates what I said in my previous post.
The following users liked this post:
One drawback to the electronic e-brake is retracting the brakes when you go to replace your brake pads / rotors. Recently, I was watching a Ram 1500 review on YouTube and they actually pointed out how there is an option in the menu system (the 12 inch display version, not sure if its all display versions or not) to retract brakes. Does anyone know if Ford provides a similar feature to retract?
My wife's Audi A4 has the e-brake, but no option to retract it. Some of the aftermarket diagnostic tools have options to do this.
Its all just one more thing that gets in the way of a shade-tree mechanic....not a huge deal in the long run, I suppose. I think anyone working on their own vehicle these days has to come to grips with the fact they need to expand the toolbox to include electronic "tools."
Sounds like the problem with the ranger is due to poor planning on the engineers and not a fault of the mechanical shift interlock. I also remember back in the day when you could shift a trans out of park with the engine off and no foot on the brake. People just learned to respect the vehicle or pay the price.
I'm still sticking by my thoughts that even though this new technology is nice it's dumbing people down to the point that common sense is fading away.
Changing / servicing rear brakes...Put the parking brake into "maintenance mode"... I tried it, it works, cheers
Activation
Deactivation
Carry out the following service mode deactivation procedure to activate the EPB system.
__________________
Activation
- Set the ignition to ON.
- Press and hold the accelerator pedal and place the EPB switch to the RELEASE (downward) position. Continue to hold the accelerator pedal and EPB.
- Set the ignition to OFF, then set the ignition to ON within 5 seconds. Continue to hold the accelerator pedal and the EPB switch.
- The EPB system will be deactivated, preventing parking brake application until service has been completed and maintenance mode has been deactivated. The yellow electronic parking brake indicator will be illuminated and maintenance mode will display on the message center.
- Set the ignition to OFF, then release the accelerator pedal and EPB switch.
Deactivation
- Press and hold the accelerator pedal and place the EPB switch in the APPLY (upward) position. Continue to hold the accelerator pedal and the EPB switch.
- Release the accelerator pedal and the EPB switch.
__________________
__________________
Recently did the rear brakes on a 17' Fusion. New rotors and pads. Did a quick youtube search and found the way to put the parking brake into service mode. Very similar, if not the same, as last post. Took about 20 seconds. Then it was a normal r&r of the rotors and pads. Basic hand tools, calipers pushed in, although some misinformed videos said they had to be turned in.
Since I started this thread earlier this year, instead of creating a new thread I decided to continue a further Electronic Brake discussion.
I'm now using the EBrake every time I park my truck in my garage. I have a reason why, for the truck to clear the the overhead garage door and provide enough space behind it as to allow access there is a 2" window of where it needs to be parked. Between this the F150 & the previous F250, I have done this at least 3000 times over the years. But every now and then, when getting the truck in position, placing it in Park and then removing your foot from the brake, sometimes it will roll 1-2" forward. For A long time, I have used the parking brake to keep the truck in that 2" window. Over the last month or so, the EBrake sometimes won't engage.
I have searched and re-read the users manual, there is nothing in there that alludes to an issue (Other than using it while traveling at speed !). So, does anybody have an idea why it won't engage ?
Thanks
Thanks
RJ sheedy
15
11-15-2016 04:41 PM
DWV88
06-27-2010 07:22 AM
