#1 #8 injectors failed buzz test. 7.3 no start
#31
I assumed they were because I had heard a ticking noise from the relay location. And from what I've heard that means it is functioning. BUT when draining the fuel I did notice that one of the main terminals was corroded like crazy. I did not do anything to it but a good clean could only help. As for checking each glowplug I have not had the valve covers off yet to get in and check
Don’t assume anything test, or ask...don’t assume.
#32
Batteries are both good, grp reads same bolts as battery. However. After turning the key over the 2 wire plug going to the turbo pedestal began to click very loud and rapidly. I unplugged it for the time being. Would that cause any issues? I also noticed that there was a rubber o-ring on the valve cover wiring harness that was out of the plug and about an inch down the wire. Next step is ohming each glowplug and injector
#33
#34
If it's this connector - just a reference photo, I have no idea if this is a good replacement part - then issues with this harness UVCH could definitely be part of your problem. The wires are for both the GP's and the injectors, and that o-ring is both an insulator and a gasket, so oil / water intrusion could affect either or both of those circuits. Sometimes, removing the VC and cleaning these connections and trying the to run it w/o the VC on - so there's no compressive forces on the connector - can reveal a bad connector that might otherwise ohm out good. Your multimeter uses low voltage for resistance checks; the GP run high amps and the injectors are high voltage..
. So is there a way to test glowplugs or injectors with a test light then? Like after the vc have been removed?
#35
#36
Okay I'm at a loss now. After the truck fired up it ran for a few seconds and blew out tons of white smoke. I turned it off as I had the valve covers off and its parked on the side of the road. Waited 2 days for ccv o-rings to get here got it all put back together and bam. No start. There is occasional puffs of white and sometimes grey smoke that comes out of the exhaust. Today is the first day over 0 since I had it running(it was 40° that day) and it simply will not fire up. Left it plugged in all night got oil temp up to 60° and it still will not start. I'm charging the batteries again and am going to try a small hit of ether to see if that will work. If it doesnt then I think I am down to a loss of compression so by by powerstroke
(and the power point fuse was blown, if that changes anything at all)
#37
#38
that's what I was thinking so I removed the same valve cover checked the connection but then but the VC back on. Not tightened or anything just in place with 1 bolt in. Is it possible for it to create a short with the vc on??
#39
The pins in the harness or the gasket plug can be bad. some times they get loose and arc till damage is done.
The following thread has some pictures but they are the extreme example. Some others are just barely noticeable unless you really look
https://www.ford-trucks.com/forums/1...o-start-3.html
Here's one with a barely burned pin
https://www.ford-trucks.com/forums/1...enter-pin.html
#40
#41
You've already done a lot of troubleshooting, so unless you know you've found a guy who's really familiar with the 7.3PSD, you're either gonna spend a lot of money on time or parts, or both. I wouldn't think just having the VC resting on the gasket would mess it up, but who knows. And that still might not be your problem. WD40 is great for cleaning electrical connections if you wanna check those again. It can idle without the VC's on, that's a good way to watch each injector and look for oil exiting from the deflector spout. Use Torque Pro to do some logging while cranking. Just turning on logging doesn't record anything - it's not related at all to whatever gauges you've set up. Look under Settings > Data Logging & Upload > Select what to log. In my previous list I forgot to add IPR, but you have a gauge for that so you know about it. The data will be saved to a file on your device and then you'll need to get that to your PC and open it with Excel or whatever spreadsheet software of choice. Or, if you're sure of what to do with it then you could post it here (if you have enough posts to allow attachments) and someone here - I might if I get a chance - could sort it and help out.
Also, plugging in the block heater really makes a difference if it works. Today it was 25° out and when I connected Torque Pro EOT read 77°. Block heater was on for maybe six hours.
#42
#43
its getting to almost the mid 30's today, the first time since it started, so maybe the little warmer weather will help
#44
A data log of just cranking the engine over can show what's off and keeping it from starting. Old, cold or dirty oil can affect injector and IPR operation. I started my truck yesterday afternoon for the first time this year. Around 10am my battery voltage was around 9Vdc and it was 25° out; I set a small battery charger on the a/c compressor and used a dual outlet extension cord to power that and the block heater together. At 4pm it cranked right over and fired up.
#45
The data I collected showed me that everything us working correct. I've got the block heater on now and I'm going to charge up the batteries again. Just tried to start it and it cranked over real nice with a 100 amp boost but she woulndt start. Good amount of grey smoke this time. My guess is injectors are pretty gummed up. The owner before me said it sat for over a month before I bought it
Christopher Bary
07-04-2016 06:02 AM
ogzilla
01-18-2004 10:16 AM
