Computer Chips & Tuners
ELM 327 adapter work for brakes and tire pressure systems???
Old 02-01-2019, 03:56 AM
RSCHAP1's Avatar
RSCHAP1
RSCHAP1 is offline
I have a bunch of the cheap ELM 327 OBDII bluetooth adapters and use the Torque app for scanning codes on my vehicles.
Recently my 2008 Explorer has intermittently been showing tire pressure monitor faults and tire sensor faults.
Nothing shows up when I scan it with Torque.
Kind of assumed that it wouldn't show since not engine or chassis related and different systems.
BUT...
Now I am wondering if there is any other app(s) of scan tools that would allow me to see stuff like the ABS and TPS codes without being too pricey???
I am assuming that one of my tire's sensors has a battery about too die since it is over 10+ years old now.
But had hopes that I could at least diagnose it and find out what is going on without spending too much.
Appreciate any help, advice, and insight.
THANKS very much ! ! !
Old 02-15-2019, 11:37 AM
RSCHAP1's Avatar
RSCHAP1
RSCHAP1 is offline
Guessing this is just happening when it gets REAL cold...
I been getting tire pressure monitoring system and tire pressure sensor lights when it gets real cold.
I counted 28 flashes before it went solid.
Mean anything???
Appreciate it if anyone knows.
Thanks always
Old 02-15-2019, 04:52 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Mean anything???
It flashes for 70 seconds. The number of flashes doesn't communicate anything.
To access the ABS and the TPMS systems, you will need 1) an interface that connects to the MS-CAN bus and 2) an application that can talk to subsystems that are on that bus.
For a "cheap" ELM 327 device to work, you'd need one that has the switch or that has been rewired. As far as I know, Torque doesn't read the MS-CAN bus unless you use custom PIDs. Forscan, however, should be able to do it.
Old 02-16-2019, 09:12 AM
RSCHAP1's Avatar
RSCHAP1
RSCHAP1 is offline
I have heard about Forscan a few times.
I will have to look into that some more I guess.
Appreciate the knowledge THANKS
aquaman
6.4L Power Stroke Diesel
27
06-02-2017 08:35 PM
mantta
2009 - 2014 F150
07-10-2010 06:54 AM
ernesteugene
42
12-21-2009 02:20 PM
now_exowner
1997-2006 Expedition & Navigator
12-12-2005 07:14 PM
phxflyboy
10-05-2004 11:24 PM
Quick Reply: ELM 327 adapter work for brakes and tire pressure systems???
