4" Exhaust. What to get/not to get?
Old 02-01-2019, 01:56 PM
dmd's Avatar
dmd
dmd is offline
The problem with the stock setup is the very restrictive muffler. It doesnt look like you are after big power and flow. I would just chop out the muffler and add a
4-inch FTE resonator and call it good. If you decide to upgrade you can still use the resonator. Cheap and I bet it will get you what you need.
Old 02-01-2019, 04:15 PM
00t444e's Avatar
00t444e
00t444e is offline
I paid $240 for my 4" Diamond eye 5 years ago and it's still holding up fine.
Old 02-02-2019, 05:13 PM
hydro man 17's Avatar
hydro man 17
hydro man 17 is offline
I am a Magnaflow kind of guy. Don't recall the price but I know it was not the least expensive. However the fit was perfect ad the system came with all of the correct pieces for any configuration, you just wind up with some spares to play with.
Old 02-03-2019, 09:19 AM
Brandonpdx's Avatar
Brandonpdx
Brandonpdx is offline
Originally Posted by L-ight
Yea I figured it was a muffler. Kinda threw me off for a bit haha. I think straight pipes would be too loud, especially when I will be having little ones riding in the back.
It's not that different sounding. The engine clatter is still far noisier than 4" straight unless you're really womping on it. I would maybe try what DMD suggested and ditch the stock muffler for a piece of straight pipe or a straight through resonator. That is probably where most of the gains come from by getting rid of the entire stock exhaust. Getting rid of the EBPV also helps a little.
Old 02-04-2019, 10:10 AM
'88 E-350's Avatar
'88 E-350
'88 E-350 is offline
Straight piped is considerably louder. Not as loud as a straight piped gasser, but still loud. Possibly more noticeable outside, but still quite noticeable inside, and more so in an Excursion than a pickup.
Many have argued that the DP is where the gains are and that the stock muffler is fine to 400HP. From my wee bit of testing, the stock muffler appears to be slightly restrictive even at stock power, and more so with a tune. Haven't done a before/after test on a DP.
Old 02-04-2019, 03:26 PM
L-ight's Avatar
L-ight
L-ight is offline
Yea I am probably going to go with the Diamond exhaust from above. Also going to purchase a black exhaust tip 4" inlet and 5" outlet. Nothing too big. Figured 5" should be ideal.
Old 02-04-2019, 03:56 PM
Sous's Avatar
Sous
Sous is offline
Received 4,436 Likes on 2,839 Posts
I have a 4" MBRP with the 5" polished tip at the end and think it looks good. Like you said, ideal size for a truck like ours.
Diamond makes a nice product, let us know what you think of it once installed.
Old 02-05-2019, 08:10 AM
F250_'s Avatar
F250_
F250_ is offline
My son "straight piped" his '02 7.3 by simply cutting off the stock muffler. He liked it, but being the old fart I am, I thought it sounded like a diesel ricer fart can myself and was obnoxious throughout our neighborhood just because of the many hills to get up and down in/out of the subdivision. It sounded nasty to me (nasty being used here as a negative term).
Old 02-06-2019, 02:50 PM
HueyCrew's Avatar
HueyCrew
HueyCrew is offline
I transferred the S&B cold air intake (#75-5062) off my '01 that got squashed and went with the MBRP 4" turbo back straight pipe. I guess the long bed moves the noise back enough that it isn't bad in the cab. Not real sure about performance gains but the EGT did drop. A shop did the install and instead of the clamps that came with the system they welded the pipes together.
btm991
11-13-2009 08:31 AM
SilverBullet131313
26
06-04-2009 08:24 AM
BigNiner19
Exhaust Systems
01-15-2009 05:44 PM
orng1
08-02-2008 12:43 AM
Jay03
15
05-09-2006 05:47 PM
Quick Reply: 4" Exhaust. What to get/not to get?
