Setting up a 2003 Expedition to tow with brakes - Ford Truck Enthusiasts Forums
Old 01-29-2019, 11:59 AM
hunt1moore
hunt1moore is offline
hunt1moore is starting off with a positive reputation.
I just acquired a 2003 Expedition 2wd, 5.4 that I need to use to tow a trailer that has brakes. It currently only has a factory flat connector.
I would like to add a brake controller and 7 way connector. My question is what is the best, easiest, cost effective way to get this done. I can do it myself, I just need to know the best parts to buy and where.
Thanks!
Old 02-11-2019, 06:02 AM
senix's Avatar
senix
senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
etrailer.com is probably the best source for the wiring harness and a trailer brake controller. A Prodigy controller should be good.
Don't forget the hitch. Does it have one and what is the rating of it?
Old 02-13-2019, 09:45 AM
hunt1moore
Yes, it has a factory hitch and 4 pin. Not sure of the rating.
Thanks for responding. I'll check them out.
Old 02-19-2019, 07:41 PM
Jakerichards1
Jakerichards1 is online now
Jakerichards1 is starting off with a positive reputation.
Plus one
Plus one on etrailer and prodigy controller.
An afternoon and about 250$ and you will be set.
You may may need or want to add constant power and or back up lights to your new 7 way receptacle on the truck depends on your needs.
Campers want constant 12v for battery charging and lights and fridge and stuff.
Stuff to consider.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
