Affordable high quality zip ties
In some cases you want something cheap because you don't want to take the oxy-actl to you nice EXPENSIVE Snap-On wrench and bend it in a shape for a job.
No problem doing that to a Harbor Freight is not so bad to heat up and bend to meat the need.
Then there is the case where what they have does a really good job. So you get the tool that does the job.
Here are some good prices on high (and low) temperature heat stabilized nylon 6,6 (-40*F to 257*F). 50 psig and 120 psig rating. UV stabilized. Problem is shipping costs are HIGH!
https://www.advancedcableties.com/pr...at-stabilized/
50 psig - various lengths
https://www.heatshrink.com/cable_zip_ties/al-07-50-30-c.as
https://www.heatshrink.com/cable_zip...11-50-30-c.asp
https://www.heatshrink.com/cable_zip...14-50-30-c.asp
120 psig 14"
https://www.heatshrink.com/cable_zip...4-120-30-c.asp
120 psig 14"
CBB9M
Electrical Systems/Wiring
03-16-2023 08:36 PM
krooser
09-02-2014 07:42 PM
