Added remote start 2014 F150
I just finished adding remote start to my buddies 2014 F150 for $60.00! The F150 forum claimed all 2014 F150 come with remote start.
So i got this key; https://www.keylessentryremotefob.co...-ford-f150.htm and my buddy had it cut at the dealer
for free! I used forscan to change; BCM 726-19-01 X1XX-XXXX-XXXX remote start activated, IPC 720-01-02 XXX-X3XX-XXXX
remote start in menu with auto heat/cool or last setting & run time. Had to program the truck to accept the new key and reprogram
the remotes so the 4 button key would start the truck. Press lock then start 2 times and presto she fired right up!
I have only used the feature rarely. At home I keep mine in the garage and western Oregon does not get too cold normally anyway. I only make emergency trips east of the Cascades in the winter. When I have I was grateful for the feature, nice to let it warm before clearing a windshield and all. A little confusing to an oldster like me when trying to drive off though. I learned to just turn it of and restart, easier on old brains.
Other than that, not too hard of a job. I still need to enable the readout for run time, as 10 minutes hardly warms anything up at -26F..............
Not that I really need Remote Start here, but hey for $60 why not. I have seen in FORScan where I enable the the Remote Start, so that's easy.
My question is did you program the new Remote & re-program the old Remotes yourself or take it to the Dealer?
Thanks, Warren
You are programming the new key to start the truck first, chip matching. Great you tube video on this. Install original key and turn ignition on for 5-10 seconds, remove 1st key install 2nd OEM key turn ignition on for 5-10 seconds. Remove key and install 3rd key to on and the locks should cycle on/off. I saw a 5 digit number on the display after the 2nd OEM key was on for 5 seconds.
Now that the key starts the truck, time to program the lock/unlock/auto start. Close all doors and press the unlock on the door, then using the OEM key cycle the key on/off 8 times then remove. Install new key and cycle on/off 8 times. The door door locks should cycle if programming was complete
My current range is about 75 yards ............... would that indicate that I have the optional antenna already ? If I dont, can I expect the optional antenna to extend my range beyond 75 yards ?
