6.9 to gas
6.9 to gas
I just bought a 1984 6.9L diesel and as I was telling a friend about the truck he told me I should put 351 heads on the engine make a few other adjustments and just run gas through it since it has bigger pistons than a normal gas engine. I was just wondering if this was possible to do, as I have never heard of this being done before. thoughts/ opinions?
Welcome to FTE.
Even though it's not April 1st, this is hard to take seriously.
But just in case, your friend is full of beans. There is no relationship between the 6.9 and any 351 gas.
Trying to convert a 6.9 to gas would be beyond foolish, and probably outright impossible.
If you don't want a diesel truck, sell that '84 and go shopping.
You could do a powertrain swap, but it would make more sense to trade for a gas truck.
Running Gasoline through the Injection system would be short lived for sure...
Back in 1935 International Harvester came out with their first Diesel Tractor, for farm use.
This engine, model WD-40 started on Gasoline, and when warmed up would be shifted
over to Diesel.
I remember seeing an old International Road Grader with one of these engines. Row of
Spark Plugs down one side and Diesel fuel Injection down the other side.
Yeah there is no way to run a 6.9 on Gasoline unless you have some very deep pockets
for some serious redesigning.
You could try gas in it and let us know how it works out. People dump all kinds of other
crap in the tank and they keep on going.
Charlie
over to Diesel.
Charlie
There were some boys back in iowa or something that custom cnc'd some heads for a 3208 and ran it on methenol... Either way the IDI doesnt even have interchangable parts with the gas engines they were "based off". I think your friend may have confused IDI for 5.7 idi and 351 for 350, but either way the pistons in a olds 350 are smaller than a standard chevy 350. Further more, the bore in a 6.9 is 4", the bore in a 302/351 is 4" so wrong again, the heads between 302 /351 are the same, so strike again, the heads on an idi already flow great, as good or better than stock windsor heads.
Received 3,090 Likes
on
https://classicoldsmobile.com/forums...sel-350-a.html
I'm convinced the Olds 5.7L IDI was a converted Olds 5.7L gasoline engine. This is contrary to what many believe in the Oldsmobile community. As you said, the Olds 350 and Chevy 350 were NOT the same engine. The coil and distributor cap were the only common parts. Here's the place to get info on the Olds 350 diesel.
Not so much--heck, not at all with the 6.9.
Yea, the 5.7 diesel is a 5.7 olds that was converted. They did use their own blocks, which were a bit heavier, but that was also one of the major failures of the olds diesel. The blocks were green and warped VERY badly. Ive heard stories in the drag racing circles that if you have a good 5.7 diesel block that they are desirable for hot rods because of the extra strength, and maybe something to do with how much they can be bored.
As for the 6.9/7.3, you could absolutely convert one im sure, with copious amounts of machining, throw a carb on there, distributorless ignition etc. but good luck getting it to run at 21:1 compression, even with race gas or methanol.
Actually I saw some recent research that said an engine using diesel injection ignition to burn gas also in the combustion chamber was more efficient than a gas or diesel engine, although I'm sure that would cost a fortune to play around with.
as for converting a diesel engine to gas, I guess in theory all it needs is less compression and spark plugs and bolt a carburetor and ignition system on. Oh wait that's quite a bit of stuff 😆
