F650 No crank
Old 01-24-2019, 05:20 PM
dale1967dc
dale1967dc is offline
dale1967dc is starting off with a positive reputation.
F650 No crank
2018 F650 6.7 L diesel. Will not crank. Was cranking fine and it just stopped. Truck has 9000 miles on it
Old 01-25-2019, 05:55 PM
lariatbob's Avatar
lariatbob
lariatbob is online now
lariatbob is starting off with a positive reputation.
Neutral safety switch? May not think it's in park or Neutral. Try putting it in neutral and see if it cranks. Same for possible brake light switch? Do brake lights work?
Old 01-26-2019, 06:00 AM
dale1967dc
I tried putting it in neutral and still wouldn't crank. I will check the brake lights. Truck only has 9,000 miles on it. It was cranking fine then just stopped.
Old 01-26-2019, 07:33 AM
UP_There's Avatar
UP_There
UP_There is offline
UP_There has a brilliant futureUP_There has a brilliant futureUP_There has a brilliant futureUP_There has a brilliant futureUP_There has a brilliant futureUP_There has a brilliant futureUP_There has a brilliant futureUP_There has a brilliant futureUP_There has a brilliant futureUP_There has a brilliant futureUP_There has a brilliant future
I've been fighting this problem for months. Mine is a 2011, and I'm hoping I have it fixed now. Another guy on here, had the exact same issue, and had his PCM re-flashed and it fixed it for him. I had mine re-flashed yesterday, so we will see how well it fixed mine in the next week or so.
I did all of the physical checks, starter connections, alternator, good batteries, neutral safety switch, relays, fuses, ALL connections were good. It's been frustrating. The way mine would act, was I would have power to everything, but NO crank to the starter, I could hear the fuel pump, and all systems seemed good, except no crank...
Old 01-26-2019, 07:47 AM
dale1967dc
Yes I checked all the preliminary stuff also. Everything is fine. This truck is under warranty but customer doesn't want to tow it to the dealer.
Old 01-26-2019, 01:20 PM
UP_There's Avatar
UP_There
UP_There is offline
re-flash did NOT fix my no cranking issue. Back to the shop next week....
Old 01-26-2019, 08:06 PM
Troy Buenger's Avatar
Troy Buenger
Troy Buenger is offline
Troy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to behold
Did you check the hood switch?
Old 01-26-2019, 08:17 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
ford390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud of
Is there a PTO? There is a starter inhibit shown in the body upfitter guide. The next likely cause is the firewall bulkhead connection check for moisture. It's on the drivers side and runs down and crosses the frame.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
