Cam for my 75
Old 01-22-2019, 10:58 PM
Gene Wyatt's Avatar
Gene Wyatt
Gene Wyatt is offline
Cam for my 75
Hello I’m new to your forum and love the site! I have a 1975 for F150 4X4 with a 400 with C6 tranny.
I am wanting to put a cam kit in the motor but nothing super extreme.
I was thinking about the thumper cam but would I have to change my torque converter if I add this cam?
Thanks.
Old 01-23-2019, 11:11 AM
CelticOne's Avatar
CelticOne
CelticOne is offline
Regular User
Are you sure it is a 400? If it is, it won't be original to the truck. The 351m/400 were available in 77 and up.
Old 01-23-2019, 12:26 PM
wyrm73's Avatar
wyrm73
wyrm73 is offline
Post some pictures of the engine if you are not sure, though it is pretty easy to tell the difference between the two. If the valve cover covers up part of the intake as well, you have a FE engine (most likely a 360 if original), as a 75 should. Also, if you could post a link to the cam you are talking about. Probably the most important thing with a cam upgrade is whether it will work with the stock valve springs, more so than the torque converter. Without knowing the spec of the cam, as long as it is a mild upgrade only, then the stock torque converter should be fine I would think.
Old 01-23-2019, 07:35 PM
ranger140892's Avatar
ranger140892
ranger140892 is offline
Thanks.
With a name like "Thumper", yeah I'd imagine you'd have to change the torque converter. Read cam descriptions and think about idle quality. If it won't idle at around 650 rpm, you'll need a looser than stock (higher stall) converter. And there are other considerations with high lift and extra overlap camshafts. Low vacuum being one of the biggest. Air flow also. Your stock cylinder heads won't flow enough on the intake or exhaust side to see much benefit from a hot camshaft
Old 01-23-2019, 09:32 PM
440 sixpack's Avatar
440 sixpack
440 sixpack is offline
Received 1,530 Likes on 1,124 Posts
A thumper cam would be a joke in a stock 400 forget it. the convertor would only be a part of what you need to change.
Figure out what engine you have first, if it's really a 400 someone went to a lot of work to go backwards.
Old 01-24-2019, 04:28 AM
AKsilvereagle's Avatar
AKsilvereagle
AKsilvereagle is offline
X2 on this post.....
The 351M/400M is a merely designed very torquey 2 barrel head with limited potential as you cannot really build it for horsepower.
Choice of cam selection upmost importance is it needs to match with a set of valve springs that will handle the cam specs, followed by what kind of cylinder heads are capable of flowing air in and out to increase it's performance potential, and what one really wants for performance if venturing beyond the stock or mild build zone (beyond 260 advertised duration or beyond 210 duration at .050 lift).... which means modifying other components while sacrificing engine vacuum, fuel efficiency, $$$$$$$$$$, etc.
I don't see much benefit of a radical cam on a 400M either unless it is a seriously modified cylinder head of sorts.
What are the cam specs of this "thumper' cam ?
Old 01-24-2019, 02:02 PM
dogdays's Avatar
dogdays
dogdays is offline
That was fast!
First of all unless someone swapped one in, your 1975 truck doesn't have the 351M or 400 engine. If you are lucky, it's an FE 390 or 460, if you want power. Post the VIN and you will find out.
Second, it's a surprise that people here jumped on the 400 so quickly. 400 variants have won or placed in Enginemasters more than once. Tim Meyer has a handle on building 400hp 400s, that should be enough power for most folks. Think 351Cleveland's big brother.
The stock M head flows enough to support 400hp. The critics don't understand camshafts, either. Using a longer duration camshaft is a common way to crutch a low-flowing head. Modern engines are making 1hp/cubic inch with 0.050 lift durations of around 210 degrees. That's because the heads are so good. Older heads with which we are familiar might need up to 240 degrees at 0.050 lift to make 1hp/cubic inch. So saying a head doesn't flow enough to use a larger cam is nonsense.
R.
Old 01-24-2019, 10:03 PM
ranger140892
R.
Please don't suggest to this member that he can make more than double his horsepower on a stock 400 with only a camshaft swap.
Snorri_B
06-05-2012 01:51 AM
a63unibody
10-30-2010 02:56 PM
Aquaman78F100
07-02-2007 10:58 PM
AceTrucking
04-23-2004 12:40 PM
brianlr77
1978 - 1996 Big Bronco
08-03-2002 08:36 AM
Quick Reply: Cam for my 75
