2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Steel vs. Aluminum - In Real Life
Old 01-22-2019, 09:08 AM
Florit17's Avatar
Florit17
Florit17 is offline
Florit17 is starting off with a positive reputation.
A friend of mine was hit head-on (headlight to emblem) about a month ago. Each vehicle was traveling at ~50 MPH, an approximate 100 MPH collision. My friend was driving the white, 2017 CC, LB, F350, PSD. The other driver was in a 2016 CC, SB, F350, PSD, and was 'distracted' according to the Highway Patrolman. Both drivers were transported to the hospital - My friend had a broken ankle and a broken jaw. The other driver had 2 broken legs and other 'critical' injuries that we never learned more about. Most likely the result of the beefed up frame, but after examining the pics, I feel a lot safer in my aluminum truck.
Old 01-22-2019, 09:21 AM
FractureCritical
FractureCritical is online now
FractureCritical is gaining momentum as a positive member of FTE.
that's not gonna buff out.
Old 01-22-2019, 09:47 AM
DSLTRK60's Avatar
DSLTRK60
DSLTRK60 is offline
DSLTRK60 is gaining momentum as a positive member of FTE.
The technology is amazing. You can see where they wanted to direct energy in a crash if you look at the new frame. Glad no one was killed.
Old 01-22-2019, 10:02 AM
2009kr
2009kr is offline
2009kr is gaining momentum as a positive member of FTE.2009kr is gaining momentum as a positive member of FTE.
I'm glad everyone survived. The new truck looks like it maintained the integrity of the cab much better than the older model (as expected).
BTW, a head on like this is a 50 MPH crash, not 100 MPH. It's exactly like hitting a brick wall at 50 - the front of the truck hits a vertical plane and stops at that plane in both cases.
Old 01-22-2019, 10:06 AM
1956Fatfenders's Avatar
1956Fatfenders
1956Fatfenders is offline
1956Fatfenders is gaining momentum as a positive member of FTE.1956Fatfenders is gaining momentum as a positive member of FTE.
I wonder if the doors were removed on the 2016 to extradite or if they blew off from impact? Sounds like all may be OK which is great, but that 2017 cabin is in much better condition in this particular set of circumstances.
Old 01-22-2019, 10:10 AM
Turbo Dog's Avatar
Turbo Dog
Turbo Dog is online now
Turbo Dog has a very good reputation on FTE.Turbo Dog has a very good reputation on FTE.Turbo Dog has a very good reputation on FTE.Turbo Dog has a very good reputation on FTE.
Glad your friend made it through that crash...it does look like the Aluminum cab did better but that could be a matter of the direction of the hit.
Old 01-22-2019, 10:39 AM
tony m 6.7's Avatar
tony m 6.7
tony m 6.7 is offline
tony m 6.7 is gaining momentum as a positive member of FTE.
Aluminum absorbs energy differently than steel and the newer beefed up frame is another benefit in a crash.
Old 01-22-2019, 10:42 AM
Adam R
Adam R is offline
Adam R is gaining momentum as a positive member of FTE.Adam R is gaining momentum as a positive member of FTE.
One of the reasons I like driving bigger vehicles is that it increases the odds of survival if someone hits you. Odds are that whoever hits you will likely be in a smaller vehicle. In this case, the two were pretty equally matched weight wise and it does indeed look like the 2017 fared better. Good news that both drivers survived. I imagine the outcome would have been different for both drivers if the black vehicle had weighed half as much.
Old 01-22-2019, 10:51 AM
harmanrk
harmanrk is online now
harmanrk is starting off with a positive reputation.
I think the passenger side tow hook on that white one is still usable.
Old 01-22-2019, 10:52 AM
f350ktm's Avatar
f350ktm
f350ktm is offline
f350ktm is gaining momentum as a positive member of FTE.
A friend of mine was hit head-on (headlight to emblem) about a month ago. Each vehicle was traveling at ~50 MPH, an approximate 100 MPH collision....
Wow, really happy to read your friend had relatively minor injuries and that the other driver survived. Technology is great on the trucks. Seems like not that many years ago both of them would likely have died in that kind of crash.
On the subject of 2 vehicles head on both at 50 mph, it's actually a 50 mph crash for each vehicle. The same as a vehicle hitting dead stop into a wall from 50 mph. I always assumed that scenario represented a 100 mph crash for each vehicle but physics dictate otherwise.
An episode of Mythbusters years ago proved this to my satisfaction with real world demonstrations...
Old 01-22-2019, 11:19 AM
Alaskan_Warbird's Avatar
Alaskan_Warbird
Alaskan_Warbird is offline
Alaskan_Warbird is a splendid one to beholdAlaskan_Warbird is a splendid one to beholdAlaskan_Warbird is a splendid one to beholdAlaskan_Warbird is a splendid one to beholdAlaskan_Warbird is a splendid one to beholdAlaskan_Warbird is a splendid one to beholdAlaskan_Warbird is a splendid one to beholdAlaskan_Warbird is a splendid one to behold
Very glad your friend is okay and that he was driving the better truck. He was alone in his truck? It looks like if he'd had family with him, they would've been okay too. Those pictures are horrifying to me, from personal experience, and make me very glad to be driving my dually.
Many years ago, I was hit head-on by a drunk driver. I was driving a company owned F150. The other guy was in a lifted Bronco. They put our closing speed at "over 90 mph" and my truck was bent in half - the rear wheels weren't touching the ground and the engine was up under the dash. I wasn't wearing a seatbelt and my face was smashed into the steering wheel while I was in the middle of cussing the guy out - I was right in the middle of yelling something along the lines of, "If I survive I'm gonna kill this motherf..." *boom* One of the worst injuries I had was from biting a dime size chunk out of my lower lip which was bleeding profusely down my coat and shirt, and horrified all the first responders (I also absorbed most of the impact through left arm, cracking ribs on left side, bent steering wheel in half, lower legs flew up into the dash but didn't break, and had severe whiplash). Moral #1 - big truck wins. Moral #2 - don't drink and drive, you could kill someone. Moral #3 - always wear your seatbelt. Moral #4 - if some drunk moron is going to hit you head-on, don't drop the F-bomb right at the point of impact.
Again, very glad your buddy is okay. Sure hope the 'distracted driver' has good insurance. And hey, your buddy will hopefully get a new rig.
Old 01-22-2019, 11:23 AM
coolidge54's Avatar
coolidge54
coolidge54 is offline
coolidge54 is starting off with a positive reputation.
That's why I drive a 2017 F350 6.7 and not some tin can Honda civic. Very glad to hear both drivers survived wow.
Old 01-22-2019, 11:37 AM
VA13FX4's Avatar
VA13FX4
VA13FX4 is offline
VA13FX4 is gaining momentum as a positive member of FTE.
This type of Ford on Ford crime is just intolerable!
Old 01-22-2019, 01:37 PM
onebadaries
onebadaries is offline
onebadaries is starting off with a positive reputation.
Looks like every airbag was deployed
Old 01-22-2019, 02:48 PM
Imadentguy
Imadentguy is offline
Imadentguy is starting off with a positive reputation.
Thats a hard hit. They are both lucky to be alive.........especially the dude in the black truck.... yikes
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
