1989 F-150 Dust Cover, front wheels help - Ford Truck Enthusiasts Forums
Old 01-21-2019, 09:23 PM
Tarheel45
Tarheel45 is offline
Tarheel45 is starting off with a positive reputation.
Ok, posted earlier about a clogged vapor line, problem solved. Now, continuing my rust restoration, the dust covers on the front wheels have completely rusted out. I have looked online and canít find them anywhere, what should I do?
1989 F-150, 4.9l, 4X4 XTL Lariat
Thanks for any help and advice.
Old 01-23-2019, 11:41 AM
timbersteel's Avatar
timbersteel
timbersteel is online now
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
Dust covers...or do you mean brake/rotor shields?
NOS is all I can think of. They're Unobtainium. You may find something from LMC or JBG, but chances are slim.
A lot of us just remove them and let it be.
Maybe others will chime in.
Old 01-23-2019, 04:24 PM
Roger T. Pipe's Avatar
Roger T. Pipe
Roger T. Pipe is offline
Roger T. Pipe is starting off with a positive reputation.
They're nothing but trouble and you're better off removing the remaining pieces and be done with them. I'd be willing to wager that 95% of the F-series here in the Northeast are running without them.
Old 01-23-2019, 05:23 PM
95fiveoh's Avatar
95fiveoh
95fiveoh is offline
95fiveoh is starting off with a positive reputation.
Clarify what you mean by "dust cover". Do you mean the grease caps, or the brake shields? If it the brake shields, don't worry about them. They rust off all the time and absolutely aren't needed. If you are referring to the grease caps, you need to replace those. They should be available at any auto parts store.
This is a grease cap-
Old 01-23-2019, 09:42 PM
Tarheel45
Thanks for all the advice. I am talk about the rotor dust covers. Several responses indicate just leave them off. I like that idea, since they have rusted off!
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
