Possible Leaking Power Steering Input Shaft Seal - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Reload this Page >
Old 01-21-2019, 08:58 PM
Excurvelle's Avatar
Excurvelle
Excurvelle is offline
Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.
I noticed I have a small leak from my power steering, it may be the steering gear input shaft seal but I am not sure. It is too cold outside to tear down and look. If it is the input shaft seal can that be replaced in the truck? I have replaced them in my Chevelle but the Ex has a lot more stuff under the hood to work around.
Old 01-22-2019, 05:17 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
The 211-02 is from the 2006 year and should be what you need.
Old 01-22-2019, 11:07 AM
Excurvelle's Avatar
Excurvelle
Thanks! If I read this right it looks like the gear has to come out.
Old 01-22-2019, 03:45 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
One hint. Put the pitman arm back on and torque the nut down off
the vehicle. There is no room once it back in place to work.
Old 01-22-2019, 04:22 PM
Excurvelle's Avatar
Excurvelle
Good tip! It has been cold here and I was working on the truck last week. I will probably clean it off, top off the fluid and keep an eye on it. When I checked the fluid yesterday it was on the bottom mark of FULL COLD.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
