Aftermarket and newer type fuel pumps... - Ford Truck Enthusiasts Forums
Old 01-20-2019, 12:37 AM
eagle275's Avatar
eagle275
eagle275 is offline
eagle275 is starting off with a positive reputation.
I was interested to know if any of you are using newer aftermarket fuel in-tank fuel pumps instead of OEM Motorcraft. Had one in front tank that I had installed and lasted 11 years and float crapped out but was still pumping some. Motorcraft pumps are pricey that's for sure. Just want to see what everyone else is using and if there's any way to install a Jegs, Aeromotive etc and if anyone is using this with 460 engines. Thanks guys!
Old 01-20-2019, 02:12 AM
Skitter302's Avatar
Skitter302
Skitter302 is offline
Skitter302 is starting off with a positive reputation.
Sub'd, needing a new fuel pump in my C350 at the minute, try'd 3 o'reilly pumps and an autozone pump. No love.
Old 01-20-2019, 10:24 AM
Scndsin's Avatar
Scndsin
Scndsin is online now
Du Nawt Seek The Treasure
Scndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputation
Look here:
Homepage - Walbro
They are OEM for just about anything.
Old 01-20-2019, 11:26 AM
Roadrage4020
Roadrage4020 is offline
Roadrage4020 is starting off with a positive reputation.
I installed an Airtex pump from Amazon in my '90 F-150 last year and haven't had any issues with it. I hope it lasts many more years, but only time will tell.
https://www.amazon.com/gp/product/B000C1HHOO/ref=oh_aui_search_asin_title?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B000C1HHOO/ref=oh_aui_search_asin_title?ie=UTF8&psc=1
Old 01-20-2019, 04:00 PM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is online now
My4Fordtrucks is gaining momentum as a positive member of FTE.My4Fordtrucks is gaining momentum as a positive member of FTE.
Replaced both fuel tanks and pump assemblies with Spectra 5+ years ago. No problems with either pumps or sending units.
Old 01-20-2019, 05:19 PM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I have almost always used Motorcraft fuel pumps in the past. With the price of them constantly going up, I just will not pay what they are asking for them as long as there is a decent alternative. I recently got a Spectra Premium complete assembly from Summit for 120 bucks for the front tank. Seems to be working fine. One thing worth noting is that the connections and screws etc should be checked before installing.
Old 01-20-2019, 07:06 PM
animator's Avatar
animator
animator is offline
animator is starting off with a positive reputation.
Replaced my sending unit with a Spectra brand from the auto parts store. It ran fine for a few days, then started giving me low fuel pressure issues. I found a small bit of metal in the filter, so I drained and dropped the tank again and replaced just the pump with a Delphi pump. Seems to be OK so far after a couple hundred miles, but I'm not convinced it's perfect. When the weather warms up a bit, I'm going to check fuel pressure again.
If this one is bad, I'm replacing everything with Motorcraft.
Old 01-21-2019, 12:36 AM
westcoasting
westcoasting is offline
westcoasting is starting off with a positive reputation.
Old 01-21-2019, 04:37 PM
TexasGuy001
I just put a Delphi pump in our 5.0 Moutaineer and it seemed like a good part. Looked very similar to the Spectra Premium that I put in the F150. However, both were made in Chine though.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
