Knee deep and over my head, maybe
  #166
Old 05-31-2019, 01:12 PM
Kramercd's Avatar
Kramercd
Kramercd is offline
Kramercd is starting off with a positive reputation.
It is going to be a while before I can lay hands on an engine hoist. Been thinking on how to finish this build without on. Right now I'm considering removing the oil pump, or at least the pickup. Shaping wood to sit on the bolt heads of the crank bearing caps. And blocking up between there and the cross member after I finish painting the cross member. I figure I may need to stabalize the engine with a couple of straps to keep her from wanting to roll. Then paint, new motor mounts. Reblock under motor mounts to reinstall pump/pickup and pan.
What do you guys think, is this doable or a terrible idea?
  #167
Old 05-31-2019, 01:46 PM
jackietreehorn's Avatar
jackietreehorn
jackietreehorn is offline
jackietreehorn is gaining momentum as a positive member of FTE.jackietreehorn is gaining momentum as a positive member of FTE.
I replaced a rear main seal and oil pump on my back laying on a gravel driveway..It's definitely not fun but it's possible !
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
