Thinking of deleting my truck - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
Old 01-19-2019, 10:29 AM
Bohen
Bohen is offline
Bohen has a good reputation on FTE.Bohen has a good reputation on FTE.Bohen has a good reputation on FTE.
It's a 2015 I'm wanting to block off the egr and delete it . So my question is I've been trying to look things up and I'm a little confused all input greatly appreciated . Not worried about performance tunes , just for everyday driving and towing. Also input on what tuner thank you 👍
Old 01-19-2019, 11:55 AM
tradosaurus's Avatar
tradosaurus
tradosaurus is offline
tradosaurus is starting off with a positive reputation.
I went to a reputable diesel performance shop and they used the 40490 SCT BDX tuner.
The shop installed:
1) CP4 fuel prevention kit
2) H&S Intercooler pipe
3) SCT tuner
4) Flo Pro Muffler (4")
After getting the truck back I installed the No Limit Fabrication EGR block off plates (4 total)
Old 01-19-2019, 12:41 PM
Chuckfx4350
Chuckfx4350 is online now
Chuckfx4350 is starting off with a positive reputation.
The shop installed:
3) SCT tuner
what did that run you? Iím interested in this as well
Old 01-19-2019, 02:55 PM
tradosaurus
Total $2600. Not including the $100 No limit block off plates that I purchased separately.
Old 01-20-2019, 10:49 AM
The Bone's Avatar
The Bone
The Bone is offline
The Bone has a good reputation on FTE.The Bone has a good reputation on FTE.
So you want to remove something from your truck that isn't broken. And you have $3,000 lying around with nothing to do?
Old 01-20-2019, 12:26 PM
ssunit1's Avatar
ssunit1
ssunit1 is online now
ssunit1 has a good reputation on FTE.ssunit1 has a good reputation on FTE.
Runs better. No more DEF fluid. No more regens. Better mpg. More power even if you just run stock tune. If the DEF filter takes a dump you’re stuck and it’s around $3k to replace and you’re back in the same place.
The OP did more than needed just for a basic DEF/EGR delete so his cost was higher than just the basic delete package.
Old 01-20-2019, 12:47 PM
schlepprock250's Avatar
schlepprock250
schlepprock250 is offline
Guns Dont Kill People..
schlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to behold
Do the work yourself and you can delete with a reputable tuner for less than $1000. Simple work really.
Old 01-20-2019, 12:55 PM
tradosaurus
One of my DEF tank sensors was broken and I didn't want to ever deal with the potential reduction in speed because of this. If it wasn't for this I probably would have waited.
As someone pointed out if you do just the delete (tuner, unplug EGR,, removal of DPF, and new muffler install) you could probably do it far cheaper than I did.
Old 01-20-2019, 04:59 PM
The Bone's Avatar
The Bone
The Bone is offline
It's your money do what you want. I just think its a waste of money till it's broke.
Old 01-20-2019, 05:35 PM
EDC8008
EDC8008 is offline
EDC8008 has a good reputation on FTE.EDC8008 has a good reputation on FTE.
Or just park your truck in a public place and some scum sucking bottom feeder will help you out and just cut it all out for you!
Due to emissions laws getting tougher and dealers are being required to ensure all the equipment is there before they can sell the vehicle these are becoming a target. It happened to me in Edmonton Alberta last night.
Happened right in front of my hotel in a nicer part right off the main drag.
Old 01-20-2019, 07:33 PM
KodiakF250's Avatar
KodiakF250
KodiakF250 is offline
KodiakF250 is starting off with a positive reputation.
@EDC8008, I would have thought the noise from cutting the pipe and the size of the dpf would have triggered someone questioning what was happening. That's a pretty bold theft!
@Bohen, someday I suspect I'll look harder at deleting if I continue to have problems with the DEF system. I don't know if you have emission checks in your state, but I do in Idaho. A lot of diesel trucks running around here deleted though, and I think that's because the emission check just looks to see if there are any fault codes. No codes, no problem passing is my guess. So the tune would need to be thorough enough to prevent the throwing of any codes.
Old 01-21-2019, 01:16 AM
kper05's Avatar
kper05
kper05 is online now
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
The things some people will do... Unless you noticed the disturbance on the ground first, were you able to start it or did the truck error at key on? The cut wires makes this a mess of an issue.
Old 01-21-2019, 02:08 AM
Superdave71
Superdave71 is offline
Superdave71 is gaining momentum as a positive member of FTE.
I deleted before I had any emission issues so that I knew I would have a fully functioning system to reinstall when the time comes to sell the truck.
Deleting when you have a failure sets you up for potentially having to pay twice, first for the delete, then again to make it legal to trade.
Old 01-21-2019, 06:56 AM
fordboy2's Avatar
fordboy2
fordboy2 is offline
fordboy2 is gaining momentum as a positive member of FTE.fordboy2 is gaining momentum as a positive member of FTE.
this is crazy, kinda like when they were stealing the converters off cars a few years back.
Old 01-21-2019, 08:38 AM
capt caper
capt caper is offline
capt caper is starting off with a positive reputation.
It's $4000 for that setup from Ford plus labor
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
