Low Battery Warning. Entire dash shuts off and on while I'm driving.
I get a low battery warning while I'm driving. Took it to Autozone to check the battery. Battery is fine. They also checked the starter and the alternator. Everything mechanically is fine. Wanted to know if anyone has experienced the same problems. 2010 F150 XLT 2WD.
Check your ground connections too. Also, I was getting an intermittent low battery warning on my 2013 while driving. One morning it would turn over but not start. I could not hear the fuel pump so I checked that fuse. It was not only blown but burnt. I put a new 20 amp fuse in and cleaned all of the electrical connections to the fuse block, battery, and a few ground connections. So far (about 8 months now), it is still fine.
CowDawg
02-17-2000 10:14 AM
