Droopy Aftermarket Sun Visors - Ideas - Ford Truck Enthusiasts Forums
Old 01-18-2019, 11:11 PM
Superblue400
Superblue400 is offline
Superblue400 is starting off with a positive reputation.
Bought a pair of the reproduction sun visors for my 79 since the originals were toasted and crispy. I also bought the new pins and installed them in the ends of the visors. Slid them over the long pin pivots and the visors will not stay up even after having the end pins inserted in the center support. Anyone have a solution to this? Thanks.
Old 01-18-2019, 11:34 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
The ends of the visor rods (04114 in pic) have rubber tips on them (04115) that fit into the center bracket (04132) to keep them from drooping.
Lower pic:
Old 01-19-2019, 04:21 AM
privateer, eh's Avatar
privateer, eh
privateer, eh is offline
Danger City Kitty
privateer, eh has a spectacular reputation.privateer, eh has a spectacular reputation.privateer, eh has a spectacular reputation.privateer, eh has a spectacular reputation.privateer, eh has a spectacular reputation.privateer, eh has a spectacular reputation.privateer, eh has a spectacular reputation.privateer, eh has a spectacular reputation.privateer, eh has a spectacular reputation.privateer, eh has a spectacular reputation.privateer, eh has a spectacular reputation.
maybe the rods have lost some of the bend at the mounting brackets, put a wrench on the rod and slide it down to the curve and mount the rod in a vice, use wrench to put more bend in the curve, don't get carried away with re arcing the curve/bend.
Old 01-19-2019, 04:59 AM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Used OEM parts guy
77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.
Who/where did you get your repops from? Unfortunately you might have to get some better repops. Does the visor itself just fall back down in the "sun block" position? Like the visor vinyl body just spins on the outer rod? Look for a small chrome metal piece clamped on the inner and outer edge to be crimping enough material and making tension on the rod, so to speak.
As a fix you might be able to inject some two part epoxy inside where the rods insert? And glue the visor body to the rods? Its getto but might work. lol
Old 01-19-2019, 11:09 AM
march's Avatar
march
march is offline
march is gaining momentum as a positive member of FTE.march is gaining momentum as a positive member of FTE.
The fix that finally worked for me (with originals) was to place the backbone area of the visor that goes over the rod into a padded vice and squeeze it a bit. I almost overdid it and really had to work to get it back on the pin. I really don't know if there is some kind of spring clip inside or if it's just a plastic board, but it's been holding up well. The test will be this summer when it gets hot.........
Old 01-19-2019, 12:59 PM
niko20's Avatar
niko20
niko20 is offline
niko20 is starting off with a positive reputation.
Hey this is what the sun visor looks like inside if you take off the upholstery. Mine are missing the little rubber boot on the tip. It's just sheet metal clamped around the metal rod , and it spins on this rod. The other end which goes into the holder is a plastic rod and has a removable rubber boot on the tip. My driver side, the plastic rod is broken entirely.
The visor itself is just a really thick cardboard.
I cut off the upholstery so I could re-do it and make them look new again
Old 01-19-2019, 01:09 PM
meangreen92's Avatar
meangreen92
meangreen92 is offline
meangreen92 has a very good reputation on FTE.meangreen92 has a very good reputation on FTE.meangreen92 has a very good reputation on FTE.meangreen92 has a very good reputation on FTE.
On my old '82 Mustang GT, the visors would swing back into the position to block sun through the door windows, due to acceleration. I think I spread the springs or shimmed them up, to keep the visors oriented to the windshield.
Old 01-19-2019, 01:36 PM
77&79F250's Avatar
77&79F250
Used OEM parts guy
Niko20 thanks for the show all pics.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
