99 F350 7.3 - NO BOOST
The first one I have no idea, it was only a couple years old. The second one was a bad rebuild, it had 3 miles on it with no more then 15 psi of boost. I was going to take it up to 60 and boom out the fender wheel most of it went
My 7.3 currently has no boost. The truck has a brand new Garrett Powermax turbo, an 8 month old S&B cold air intake, Industrial 75+ injectors. It was chipped but I took that out and installed an Edge Evolution CS2 tuner. The tuner did nothing impressive so I sent it back. Before I removed the tuner I restored the setting back to stock. I now have NO boost and I am blowing black smoke like crazy and I cannot get the truck over 25 MPH. I think I have a leak because I was only getting about 12 lbs of boost before. At this point I would be happy with 12 because when I say NO I mean ZERO. I also changed the EBP sensor. I have not cleaned or replaced the EB line yet but I doubt that would totally kill boost. When the powermax went on it had a new wastegate so I do not think that is the issue. I removed the tube from the wastegate and there was no difference.
I am at a total loss. Please help.
Now on to a new problem. The truck will not start after sitting for 30 minutes unless its jumped. Batteries are less than a year old I getting 12.5 - 12.6 volts. I need to jump it so I can test the alternator. It is one thing after another with this thing.
Thank you to all who offered advice.
99F350bigorange
32
08-22-2015 08:22 AM
