What is the best cleaning solution for wires and rubber? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Reload this Page >
Old 01-18-2019, 08:39 AM
Meridian_Mike's Avatar
Meridian_Mike
Meridian_Mike is offline
Built Ford TOUGH
Meridian_Mike is starting off with a positive reputation.
I am about to start cleaning some of the gunk and other general crap off the wires and rubber parts inside the engine compartment. There is years of oil and dirt and grit and more dirt caked up on everything.
I want to use a cleaner that has some UMPH to it but I don't want to use something that might attack the plastic or rubber.
What do y'all use for clean-up on these items?
I was wondering about Simple Green..... IS that something that would work and maybe help the rubber parts?
Thanks!
Mike
Old 01-18-2019, 08:51 AM
niko20's Avatar
niko20
niko20 is offline
niko20 is starting off with a positive reputation.
I was thinking anything with citrus may work very well. Orange cleaners. Cut grease very well. Dont know about plastic safety for sure
Old 01-18-2019, 08:55 AM
Meridian_Mike
Built Ford TOUGH
Good suggestion.... Thanks!
I have never really tried to do any clean-up on wires and rubber during a restoration. I have always just bought the new stuff and replaced it.
On this resto... I want to keep as much original as I can. From what I see right now..... Bubba hasn't been working on this truck except for one place and I can deal with that.
Mike
Old 01-18-2019, 11:22 AM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
I use a rag dampened with Go-Jo hand cleaner. I supposed Simple Green would work too but it leaves the wires very dry. Go-Jo contains lanolin which feeds/lubricates the insulating wire jacket and a leaves a nice sheen... smells good too.
Old 01-18-2019, 11:26 AM
84espy
84espy is offline
84espy has a great reputation on FTE.84espy has a great reputation on FTE.84espy has a great reputation on FTE.84espy has a great reputation on FTE.
This may sound funny but it works. WD40 cuts through all kinds of grease and grime. Just make sure not to use it where sparking may occur and to clean off WD40 once the job is done.
Old 01-18-2019, 11:51 AM
Meridian_Mike
Built Ford TOUGH
AH-HAAAAA.... Yep, that was my concern. I don't want to dry out any wire or rubber.
Thanks so much!
Mike
RNBinc's Avatar
RNBinc
RNBinc is offline
RNBinc is starting off with a positive reputation.
Super Clean��
Old 01-18-2019, 11:52 AM
Meridian_Mike
Built Ford TOUGH
Thanks so much.... another great suggestion!
Mike
Old 01-18-2019, 08:54 PM
Stroker 1976's Avatar
Stroker 1976
Stroker 1976 is offline
Stroker 1976 is starting off with a positive reputation.
WD40 or it's generic equivalent. Spray the wires down good then use a piece of fine scotchbrite soaked with either, wipe off excess with a clean cloth.
Old 01-18-2019, 09:10 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is online now
ford390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud of
Be warned the wrong chemicals will pull all the elastomer out of the plastics. Avoid anything petroleum based, anything citrus based ( they contain methanol) and for sure do not use lye based cleansers such as purple power or super clean. The safest is actually dawn soap or simple green HD3 purple ( it's the same as simple green aircraft cleaner) and available at home depot. Then protect the plastic and rubber with 303 aerospace protectant available locally at parts stores or online.
Old 01-19-2019, 01:32 PM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Used OEM parts guy
77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.
Old 01-19-2019, 02:42 PM
NorthwestX360's Avatar
NorthwestX360
NorthwestX360 is offline
NorthwestX360 has a very good reputation on FTE.NorthwestX360 has a very good reputation on FTE.NorthwestX360 has a very good reputation on FTE.
You might want to check out how this man cleaned an entire wire harness: https://www.ford-trucks.com/forums/1...storation.html
Old 01-21-2019, 07:59 AM
Meridian_Mike
Built Ford TOUGH
Thanks so much guys.... This is some great guidance and it tells me exactly what I was wondering about.
I did NOT want to hurt my wires and rubber parts. I hope to keep as much of the original wiring as I can.
Thanks a LOAD!
Mike
Old 01-21-2019, 10:50 AM
LARIAT 85's Avatar
LARIAT 85
LARIAT 85 is online now
LARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to behold
I always used a bit of kerosene on a rag.
Old 01-21-2019, 12:56 PM
Meridian_Mike
Built Ford TOUGH
10-4... I bet that would work good. Isn't there oil in Kerosene? (Or maybe it IS oil?)
Mike
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
