6.7 radiator replacement - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-17-2019, 10:56 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
Dutter 2 is gaining momentum as a positive member of FTE.
ok so I see that everyone is taking them out threw the front. But why can’t u remove it straight up ?? Looks easier to me but there’s a lot going on on the front of the truck too. And ford just used dexcool ? Any additives
Old 01-17-2019, 11:00 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
ford390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud of
You have to remove the entire front of the truck to get it out. Strip everything and the radiator is at a angle also. There is no pulling it straight up.
Old 01-17-2019, 11:12 PM
Evan_P's Avatar
Evan_P
Evan_P is offline
Evan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to behold
And it is NOT dexcool. It is Ford Orange coolant.
Old 01-18-2019, 12:27 AM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
Well yeah not straight straight up. And I could have sworn one video said dexcool cus I remember thinking that dosnt sound right. Any aftermarket coolant that’s ford orange? Or just motorcraft.
Old 01-18-2019, 12:32 AM
ford390gashog
Its Dexcool, the Ford spec is wss-m97b44-d2 which is on the back of every bottle of licensed Dexcool.
Old 01-18-2019, 07:06 AM
99f350sd
99f350sd is offline
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
You're gonna use a mishimoto radiator right? Stock units fail all the time if you tow.
Old 01-18-2019, 08:30 AM
vermilian's Avatar
vermilian
vermilian is offline
vermilian is starting off with a positive reputation.
If you do go with the mishimoto unit. Do let us now how it works out. I’m interested in their primary and secondary rads, and would like to know how well they work compared to the stock units
Old 01-18-2019, 12:08 PM
Bigjeffs350
Bigjeffs350 is offline
Bigjeffs350 is starting off with a positive reputation.
When I changed my radiator on my 6.2 it was impossible to remove the radiator straight up due to the fan shroud. I had to remove the rad support and tilt the radiator forward for it to clear everything. I'm sure the 6.7 might be the same, impossible to get the fan shroud out. And the A/C condensor, oil cooler, tranny cooler, etc are attached to it.
Old 01-18-2019, 03:27 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
Nope I went with a csf radiator on eBay for $190 because I don’t have the $500 to dish out for a all aluminum. I’d rather replace it twice lol. I’m a certified mechanic so I got all the fancy tools to make it easier. I’m just curious why people haven’t tried removing it from the top. But I’ll play it safe and go threw front. And at work we got dexcool that’s ford approved, found that out today.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
