400 Timing Pointer
I will be going thru this rig, I just acquired from my father-in-law. He rarely drove it, it will be needing some TLC. 1980 F350 dually, Trailer Special.
Fortunately the damper is degreed for a good distance each side of zero.
I lie on the ground under the truck, set the pointer to 15 BTDC. Then get up and turn the distributor so the reluctor tooth is dead center in the pickup coil. Clamp'er down and start'er up.
I agree, there must have been a better place to put the pointer.
R.
R.
fishindave11
11-16-2008 02:27 PM
