97 supercab 4.6 windsor P0307 & P0304
Well, based on excellent advice here, I did both coil packs, plugs and plug wires on my 4.6 Windsor when I did my timing chain tensioners (also new water pump while there). All parts installed were motorcraft.
Ran so much better, yet has set check engine light a couple times now (with clearing code twice now) after a few weeks. I've also checked gas cap of course. Fresh gas, new air filter, MAF cleaned thoroughly. Idles fine, doesn't miss going down road, no ill manners, yet codes for miss on cyl 4 & 7. Is there any trouble shooting that can eliminate or verify if it's oxygen sensors? I'm just guessing at this point, but would like to verify before proceeding. Because oxygen sensors are original w/180K I "tend" to "guess" perhaps it's them. But don't want to just start throwing parts at the problem. no miss, runs fine, yet throws code showing 2 cylinders misfiring.
on
O2 sensor can not cause a miss code.
Pull off the spark plug wires and blow out the spark plug wells with compressed air. The most common causes for misfires on fresh spark plugs are: water or debris down in the spark plug well, cracked or torn COP boot or spark plug wire end, faulty COP, broken COP electrical connector or injector connector, & damaged spark plug. Remember, new parts can be bad right out of the box including spark plugs and plug wires.
Oh well, cleared codes, drove it today. Not a miss anywhere, I guess the check engine light will reset in about a month. That seems to be the pattern. There is no corresponding miss to the codes when they do set, it's like a glitch. At no time in the last couple months since both new coil packs, plugs, wires has it missed even once, yet it'll set an "emissions related code" according to my Actron scanner for 2 cylinders misfire, of which I do not see or hear or feel, and gas mileage still same around 16 mpg.
MrBookworm
1997-2006 Expedition & Navigator
01-23-2006 11:46 AM
