2018 6.2L crank over, no start - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 2017+ Super Duty
Reload this Page >
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 01-15-2019, 04:13 PM
travlnman
travlnman is offline
travlnman is starting off with a positive reputation.
2018 6.2L, 41k miles. No issues or complaints before today. Drove about an hour home last night, parked my usual spot,came out this morning,insert key. Engine cranks over at normal speed, truck doesn't start. After several attempts, can smell gas, pulled plug wire and cranked over, have good spark. Had towed to dealer, they are shaking their heads.. have no clue what's wrong. Even tried using other keyfob... nothing works. I quote " you have everything you need to fire, it just won't run " . Have read similar issues on here related to fuel pump, but I have fuel, verified by dealer, as well as spark. Put on your thinking caps boys and girls and help a brother out 😁
Old 01-15-2019, 04:19 PM
Alaskan_Warbird's Avatar
Alaskan_Warbird
Alaskan_Warbird is online now
Alaskan_Warbird has a great reputation on FTE.Alaskan_Warbird has a great reputation on FTE.Alaskan_Warbird has a great reputation on FTE.Alaskan_Warbird has a great reputation on FTE.Alaskan_Warbird has a great reputation on FTE.
Rodents in your air intake? Computer glitched and needs hard power cycle?
Old 01-15-2019, 04:21 PM
ZAR2USA's Avatar
ZAR2USA
ZAR2USA is offline
ZAR2USA is starting off with a positive reputation.
Possible timing issue or exhausts valves stuck open?
travlnman
Also.. forgot to mention, I disconnected battery for few minutes, tried again, no good.
Old 01-15-2019, 04:57 PM
kry226
kry226 is online now
kry226 is starting off with a positive reputation.
Battery putting out proper voltage? You may think it is since it sounds normal, when in reality, maybe it's not. My understanding of these modern vehicles is that when there isn't enough juice, weird things start to happen.
Old 01-15-2019, 05:03 PM
travlnman
Yep, even tried putting a charger on it. Dealer was cranking it over ,while on the computer...they saw nothing
Old 01-15-2019, 05:07 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
ford390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud of
Failed fuel pump, the gas you smell was probably from the purge valve. The dealership will figure it out the fuel pump delivery demand module will show a fault.
Old 01-15-2019, 05:34 PM
travlnman
I hope they find it quickly...I need that truck for work. Kinda hard to haul all my tools around in a rental econobox.
Old 01-15-2019, 06:14 PM
Turbo Dog's Avatar
Turbo Dog
Turbo Dog is offline
Turbo Dog has a very good reputation on FTE.Turbo Dog has a very good reputation on FTE.Turbo Dog has a very good reputation on FTE.Turbo Dog has a very good reputation on FTE.
Proper fuel pressure? Just having fuel present isn't enough for a fuel injected engine. Otherwise, if the tank has plenty of fuel in it did someone pour sugar in it? Might need to check the fuel quality.
I'm guessing that the dealer verified the ignition timing while having it connected to a diagnostic computer.
Old 01-15-2019, 06:25 PM
travlnman
Proper fuel pressure is the dealers responsibility, it's under powertrain warranty. Tank is full, no tampering with truck.
Old 01-15-2019, 11:19 PM
ford390gashog
Powertrain warranty won't cover the fuel pump. Good news the emissions warranty will.
Old 01-16-2019, 01:04 AM
JetMechJoe
JetMechJoe is offline
JetMechJoe is starting off with a positive reputation.
crank/cam sensors?
Old 01-16-2019, 01:27 PM
sjanusz01
sjanusz01 is offline
sjanusz01 is starting off with a positive reputation.
I had very similar experience about a year ago. I had truck towed and technician got it running by holding the accelerator to the floor and cranking. We think it was due to switching from E85 to unleaded. I have only used unleaded since and never had re-occurrence.
Old 01-16-2019, 03:00 PM
delorenzomp
delorenzomp is online now
delorenzomp is starting off with a positive reputation.
Somebody bumped your truck unbeknownst to you and the Fuel Safety Switch activated ??
Old 01-17-2019, 08:20 PM
travlnman
For sure no bump, it was in my yard, and I live at the end of a mile long dirt road..
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
