2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
2018 6.2L crank over, no start
Old 01-17-2019, 07:30 PM
travlnman's Avatar
travlnman
travlnman is offline
Okay , I appreciate all parties for sharing their input and great ideas and I know inquiring minds want to know
The "senior" technician came in the next day, and got it running. When I picked it up and paid the bill..the receipt said " Re-Flash PCM to clear flood condition" I don't know exactly what that means, but he said he got the idea from a TSB and I'm kicking myself for not asking him for the TSB number. I suppose it's possible I can still go by and ask him if he's willing to share. Regardless , it's running and working as it should be for now. I admit, my confidence level is medium at best. In the machine tool controls world in which I earn my keep, I deal with flash memory quite often. It's not volatile, and it's not easy to corrupt. In fact, we usually replace a flash module entirely and then reload the data if corruption occurs, because it's usually the fault of the hardware and will reoccur if it's not replaced. Time will tell I'm sure, I'm hopeful and for now, I'm happy. Thanks again for all the input and maybe this can help someone else !
Old 01-18-2019, 02:42 AM
kry226's Avatar
kry226
kry226 is offline
Glad you're back on the road and thanks for coming back and updating. Helps us all.
Old 01-18-2019, 03:08 AM
seville009's Avatar
seville009
seville009 is offline
Scroll down the link a bit and it talks about cranking and flooded throttle body
https://www.autozone.com/repairguide...96b43f803938c8
Old 01-18-2019, 05:20 AM
rwilimo's Avatar
rwilimo
rwilimo is offline
I have seen or rare occasion Fords that flood when very cold out, to clear the flood condition hold the accelerator pedal to the floor while cranking which turn's off the injectors, once it sounds like it wants to start release your foot and it should run. By flash he does not mean to clear the memory, he means to update the PCM software to the newest version which very well might have fixes for the problem you experienced.
Old 06-25-2020, 11:19 AM
Terror Dome's Avatar
Terror Dome
Terror Dome is offline
Where is the cam sensor located? I have a 2017 350 with 26K on it and am lead to believe that it may be that sensor. I've looked all over the front of the block and can't find it. I know this thread is older but i saw it mentioned so figured I'd ask
Old 06-25-2020, 02:19 PM
Cletus Hogwallop's Avatar
Cletus Hogwallop
Cletus Hogwallop is online now
Originally Posted by travlnman
For sure no bump, it was in my yard, and I live at the end of a mile long dirt road..
Any livestock?
Old 07-31-2020, 03:39 PM
Lalo Godinez's Avatar
Lalo Godinez
Lalo Godinez is offline
Same issue, ive heard one other 6.2 f250 with the issue
2018 6.2L, 41k miles. No issues or complaints before today. Drove about an hour home last night, parked my usual spot,came out this morning,insert key. Engine cranks over at normal speed, truck doesn't start. After several attempts, can smell gas, pulled plug wire and cranked over, have good spark. Had towed to dealer, they are shaking their heads.. have no clue what's wrong. Even tried using other keyfob... nothing works. I quote " you have everything you need to fire, it just won't run " . Have read similar issues on here related to fuel pump, but I have fuel, verified by dealer, as well as spark. Put on your thinking caps boys and girls and help a brother out 😁
was the fault ever corrected my truck started with just a bit of lag on the starts within 15k miles it started cranking normally but no start dealers cant find any issue, i love the truck overall would be great to fix
Eric1976mi
07-17-2017 03:40 PM
steve(ill)
08-04-2015 05:24 PM
llangbehn
18
03-01-2013 10:21 AM
cmccul002
1983 - 2012 Ranger & B-Series
04-13-2008 07:15 AM
tps0424
Modular V10 (6.8l)
08-21-2007 10:48 PM
Quick Reply: 2018 6.2L crank over, no start
