Need FL1A Oil Filter Wrench That Fits
I have one similar to what sandymane posted also large and small versions of the strap wrench that conanski posted. I also have one of the cup style that I bought my a very long time ago. I couldn’t tell you the last time I used that one. If the strap wrench didn’t work I also have big Channellock pliers. You needed to be prepared when you worked on all makes of vehicles.
on
I am with 95fiveoh, once you try the pliers style, you will never go back. The strap-type wrenches bend more oil filters than anything, at least in my experience. The problem with the strap-type is that the more force it takes to break the filter loose, the more force that is being applied to the body of the filter, which tries to crush it.
Just like My4fordtrucks, I have a giant pair of channel-locks that I used to use on stubborn filters. That's how I knew the pliers-style was for me when I first saw it. The ones I have fit into tight spaces and grip the filter better than my channel-locks.
I've heard 3/4 turns after the gasket contacts rather than 1/2 - 3/4 turns. I can't always get to 3/4 turns very easily by hand so I use a wrench to make it easy.
When I go to remove a filter after putting it on 3/4 turn past contact I usually can't get it loose by hand. And especially since I like to change oil when the engine is warmed up I definitely want to use a wrench.
I just have a cheap metal strap wrench. It doesn't deform the filter at all tightening it, because I'm really not tightening it much at all. And I've never had any trouble getting a filter loose with it the way I tighten them. Occasionally I'll get a little denting, but it always comes off.
I I'm not a fan of the conventional filter wrenches that are a metal strap that smash the filter. Worst thing ever. I've had decent luck with the rubber strap wrenches. I can't say I really care for the way those plier style wrenches you guys seem to like, but may have to try them.
on
#28
I started using the PROTO 2304 wrench in 1964 while working in a service station and it is still works the best for me.
I use it on my Ford Motorhome and all of my Ford trucks.
If need be you can use an 1/2" drive extension with it to reach the filter or work in an are where you cannot use the handle type filter wrenches.
You can also use an open end or box end wrench if need be to turn the filter.
Most of the time I just use an 1/2" ratchet with it.
You can not tighten a filer with it as that is the release direction for the tool to unclamp the tool.
Never use grease only motor oil on the gasket and hand tighten only.
#29
Mine works to both tighten or loosen a filter. As you turn it one way it will grip down. Turn it the other way and it opens up to a point, but then grips down again. So you just need to turn it farther if it's opening up.
#30
If you can get the band type over the end of the filter then the PROTO 2304 wrench will go on also.
You may have to use an open wrench with it if it is that close.
